![]() | Home > In Car Electronics > Split charger and power inverter |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 ![]() ![]() |
Sounds like a serious set up.
![]() Don't want to come over all preachy but do you really need such a set up? Decent Fridge is money well invested, we use our Engel for all manner of stuff and it works well for us on a basic leisure battery (�70 job) will run for about 3-4 days on this without running the car. I use a heavy duty relay and have a homemade split charge. We have a cheapo Halfords (Ring Can) that is a basic inverted but is used for charging laptops etc. Kettles require power! So we boil our water on a stove (Jetboil) So I guess the split charge becomes less complex if you look at the things you're running. |
As you so justifiably stated there are a myriad of threads on here with very good feedback and installation instructions with pictures on several renowned and well-tested makes.
Why are so even considering splurging more cash than necessary on an 'overkill' system (your opinion, not mine) on a system recommended by one when there is a lot of information readily available already on numerous others? �900 on a gel unit alone? ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
Cat81 Member Since: 05 Mar 2014 Location: Kent Posts: 60 ![]() ![]() ![]() |
Unfortunately not, that may have made things clearer to me ![]() Let no one start thinking they can sell me their used battery for that sort of price though ... ![]() |
captain slow Member Since: 22 Jun 2011 Location: Herts Posts: 357 ![]() ![]() ![]() |
Has anyone used the CTEK D250S Dual Battery Charger? It seems like an elegant solution to me, but I'm not an electrical expert in by any stretch of the imagination! 2.2 Tdci 110 XS CSW Corris Grey
Prince Harry's D3 (gone but not forgotten) 300 Tdi 110 CSW (gone but not forgotten) |
Not a mention of that particular one but several mentioned here of the same brand.....
If I recall correctly our sister Disco site had some form of group buy/discount offered a while ago on CTEKs and an adaptor was available through Martin to charge through your tow socket? ![]() Treat every day as if it is your last....one day you will be right!! |
Cheers, I'm also on the D3 site - I'll do a search there. Many thanks
![]() Prince Harry's D3 (gone but not forgotten) 300 Tdi 110 CSW (gone but not forgotten) |
I have my dual battery system running for over 5 years now, consisting of a Cyrix VSR (�50) and a Optima Yellowtop leisure battery (�180). Add some cable, connectors and other small hardware. I am very happy with this setup, and it is not very expensive.
I run a Waeco 40l compressor fridge on the Yellowtop, as wel as additional lights and phone chargers and the like. I also have a solar panel permanent on the roofrack for topping up the leisure battery while camping. Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
post mentions kettle some kettles are 3kw that's a bl@@dy big inverter your need!
^^^ Indeed, it is best to avoid using an inverter: most laptops and mobile chargers work on 12V (or use a dc-dc converter).
And a fireplace is much more fun than an electric kettle ![]() ![]() Click image to enlarge Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite Last edited by VeeTee on 22nd Oct 2014 7:45pm. Edited 1 time in total |
can't beat a proper whistling kettle , electric aint camping !
Glamping
![]() ![]() 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
