Home > Maintenance & Modifications > Larger front brake upgrade
Page 5 of 5 <12345
Pickles
taazzukcb wrote:
I would hazard a guess that that's a theoretical maximum based on gearing.
Not sure what box ratios 6-Pot is planning on running.
I would also hazard a guess, it probably wouldn't achieve quite those figure until it gets a blower as the aerodynamic properties of the Defender is about as good as a brick! The biggest obstacle is itself. So it'd need the extra clout of the Supercharger to get that down!
Though saying that, I'm not sure of the tuning capacity that a stock LS3 has in it!
likeomg, which Vantage S do you have and what box ratios does that run?
There is absolutely no problem with the "tunability" of the LS3, which is a very nice STRONG engine. There are cars in Aus running around with well over 800HP with no worries at all,...extremely docile too,...of course the cost ain't small, but as the saying goes, the more you spend, the faster you go!
Pickles.
Post #358337 16th Sep 2014 10:41pm
taazzukcb
United Kingdom 2004 Defender 110 Td5 DCPU Stornoway Grey
Hi pickles,
I didn't mean to sound like I was putting a downer on the LS3. I realise they are a very very strong motor and I'd love one. I was mearly wondering what sort of level of tune a 'stock' motor could achieve before starting to look at aftermarket blowers and various other bits.
Some of the kits available for the LS3 look almost like art than lumps of metal to bolt to the block!
Post #358355 17th Sep 2014 7:16am
Pickles
Taaz, Naah no worries mate,I didn't take it that way at all.
In Aus, there is HEAPS of stuff for these engines,..cold air intakes, camshafts, valve gear/rockers etc, cylinder heads, all manner of exhaust systems, stroker kits, pistons, rods, crankshafts, whatever you want,.......before you even think about stuff like turbos, twin turbos, superchargers etc!!
Pickles.
Post #358380 17th Sep 2014 9:09am
6 pot
Just got the Rakeway rear big brake kit. Not quite as sexy as the front kit but still nice.
Cheers Rob
Post #360132 25th Sep 2014 6:11pm
Pickles
Rob, that is beautiful, quality, gear.
Very jealous, Pickles.
Post #360216 25th Sep 2014 10:07pm
Likeomg
should be having my ap 6 pots installed tomorrow... got them powder coated red
will post pics if it happens.
Post #364022 12th Oct 2014 9:14pm
Likeomg
well got mine,
Post #366454 22nd Oct 2014 3:33pm
elvisandfrankie
United Kingdom 2013 Defender 90 2.5 TD HT Corris Grey
6 pot wrote:
This is (hopefully) a picture of my Rakeway big brake kit.
Hi would you be able to tell what you thought of the rakeway big brake upgrade ? As I was thinking of purchasing them.
Cheers Stu
Post #620071 28th Apr 2017 7:43am
Likeomg
I have them as above... front and rear
they are great, only problem is they are designed for a performance car it is easy to lock the tires in the dry never mind the wet
Im going to get rid of my BFG's for cooper zeons i think.
don't forget you need 18" wheels too.
Post #620159 28th Apr 2017 1:24pm
Puma1234
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
Is that with or without ABS that you lock the wheels? Does this kit work with ABS do you know?
Post #623769 12th May 2017 11:07pm
Likeomg
It does work with ABS
Post #623771 12th May 2017 11:22pm
Page 5 of 5 <12345
