Home > Puma (Tdci) > Bilsteins or Koni?
Page 2 of 4 <1234>
barbel jim
Greenmachine Thumbs Up sounds like with have very similar set ups, and are both happy !!!! That's helped the op Laughing
Post #365029 16th Oct 2014 7:57pm
redzob
Guernsey 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
@barbel jim - I like the idea of doing this over time, rather than changing everything in one go. I also agree, having had adjustable suspension on various bikes, that I'm actually very unlikely to actually tweak once they're in place.
Thanks for all your advice everyone - much appreciated. Think I'm going to begin by ordering a set of Bilsteins. Defender Puma 2.2 XS 90
Vespa GTS 300
Way too many racing bikes.
Post #365041 16th Oct 2014 8:23pm
Pickles
redzob,...great forum this, isn't it? keep us posted as to where you but the Bilsteins, how you fit them, what you think etc etc,...I wanna know, because I'll probably be going down this track at some stage, & I'm also thinking about lowering springs from Alive tuning, which only drop the Defender by 1-1.5", but are so designed that they ensure that the defender sits level.
Pickles.
Post #365110 16th Oct 2014 11:18pm
redzob
PicKeep - very similar thoughts. I emailed Alive last night re the Bilsteins and will update my post once they're fitted.
And yes, this is a great forum. Thanks all!
Post #365128 17th Oct 2014 7:24am
redzob
PicKeep = Pickles. Bl**dy autocorrect! Confused
Post #365130 17th Oct 2014 7:26am
redzob
Update
I had the Bilsteins installed over the last couple of days whilst the truck was in for Waxoyling (thanks Ben!). Early days, but I can confirm that the ride is noticeably firmer with very little of the wallowing you get with standard dampers, and cornering is much improved. Also it doesn't feel 'crashy' over speed bumps or pot holes, so pretty pleased so far. The Bilsteins were the only suspension mod I decided to do, so the landy still has standard springs and bushes (possibly the next mod?). Wheels and tyres are standard 235/16" boosts, apart from the wheel spacers.
Various owners have said that it takes a couple of weeks for the shocks to bed in, so I'll provide a further update then.
Cheers all. Defender Puma 2.2 XS 90
Vespa GTS 300
Post #370041 7th Nov 2014 8:51am
mick
Pretty sure I have seen Konis come with a lifetime warranty
Post #370205 7th Nov 2014 8:31pm
Pickles
Re: Update
Cheers all.
Thanks for the update, looking forward to further impressions.
Pickles.
Post #370214 7th Nov 2014 9:21pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
I have Koni Heavy Tracks with Pro Comp bushes all round, a B6 steering damper and an Extreme ARB (25.4mm) but kept the std springs as they were in perfect condition. I kept the height std too.
The std shocks I took off were pretty shot and had little resistance compared to the Koni's. The ride is noticeably better, seems smoother, less roll and just seems 'tighter' all round. I left them on the factory setting which I think is the softer of the two.
Don't expect to get in and it feel totally different on the first drive - it won't. It takes a while to get used to it, but overall I'm glad I did mine, it's more confidence inspiring.
I had recommendations of both the Bilstein B6's and Koni's but decided on the Koni's in the end. Anyone who has B6's will probably recommend them, and the same for anyone with Koni's, each to their own. At least the Koni's are adjustable if you want them to be stiffer.
Post #370231 7th Nov 2014 10:25pm
bga86
2015 Defender 90 Puma 2.2 HT Fuji White
Everyone with the Bilsteins fitted seems to be very happy with them Thumbs Up
Post #370360 8th Nov 2014 5:27pm
bob neville
I have Koni Heavy Traks on the TD5 and find them very good.
However, a little warning. It failed it's MOT last week due to both rear shock absorber bushes (ones that come with the shocks) being severely worn.
Garage replaced them with poly bushes and it sailed through the retest.
Bushes have lasted less than 5,000 miles. I know it is used mainly off road but I think that rate of wear is a little excessive.
Sure somebody has reported this before as well.
2013 Defender 90 CSW - sold
Post #371087 11th Nov 2014 7:42pm
Pickles
What type & grade were the bushes?....I believe there are three grades?..Soft to hard etc.
Pickles.
Post #371148 11th Nov 2014 10:06pm
bob neville
The ones that failed were those that came with the Koni's.
Garage replaced them with red poly bushes and the ride is fine.
Post #371153 11th Nov 2014 10:15pm
gilarion
Bilstein B6's, I had a full set fitted six months ago and I could not believe the differnce, well worth doing in my opinion Very Happy
Post #371262 12th Nov 2014 2:22pm
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
Did the B6 change the ride height of your car? Considering it, but I would love to keep the current height.
Post #371263 12th Nov 2014 2:35pm
Page 2 of 4 <1234>
