Home > Puma (Tdci) > Bilsteins or Koni?
Page 3 of 4 <1234>
redzob
Guernsey 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
@tookaphotoof - no, exactly the same ride height. I'm the same as you and have no particular desire to lower my vehicle. I understand the it's primarily the springs which account for the ride height (although certain shocks can make a difference). Defender Puma 2.2 XS 90
Vespa GTS 300
Way too many racing bikes.
Post #371386 13th Nov 2014 7:59am
redzob
Update
Having lived with the Bilstein B6 upgrade for a few weeks, I thought it might be good time to provide an update...
The good: Cornering is dramatically improved and there's very little of the wallowing experienced with the standard shock. On smooth roads the Bilsteins really are a significant improvement over standard.
The not so good: I live in Guernsey, which has some pretty poor roads and many potholes/poor repairs. I would say the the Bilsteins are more jarring/crashy than standard when you hit the holes or go over speed bumps. This can become quite tiring after a while. This combined with the weird pogo effect so unique to the 2.2 Tdci in the lower gears can be very annoying. I'm guessing changing to 18" wheels and lowered suspension would make this even more frustrating.
In summary - if I was on fast smooth roads all the time, I would highly recommend them and they're great for trips to the UK. With my truck spending most of its life on a small rock, I think the difference from standard is actually difficult to justify.
hmm... Defender Puma 2.2 XS 90
Vespa GTS 300
Post #375669 1st Dec 2014 8:51pm
redzob
Further update - Rear Coil Springs
I thought I'd provide a further update regarding suspension for anyone who may have an interest, as I've subsequently been experimenting with alternative rear coil springs.
I (as others) had noticed that if you put a few bags of topsoil or similar in the rear of your 90, the ride improves considerably - an effect I wanted to replicate unladen or with one rear passenger. I'd also read elsewhere on this forum that some trucks had been fitted with standard front springs (rated at 175lbs) at the rear replacing the standard (225lb) ones, and this was said to noticeably improve the quality of the ride under those conditions. Doing some research, it looked as though some progressive springs might be the best win/win solution, so I contacted Mac and Digby at Extreme4x4 for some advice.
I didn't want to change the ride height from standard, so they suggested trying a progressive pair rated at 172/350lbs. These duly arrived and were fitted by the ever capable indy LR expert, Ben. After living with them for around 3 weeks, I felt that the softer part of the spring actually bottomed out too early (potholes/speedbumps) so contacted Extreme again to see if we could try something different. This time we exchanged the springs to 150/225lbs and the ride is a real revelation. Early days, but together with the bilsteins, I think this is a great solution. Very comfortable, and much improved handling. I also just wanted to send a big Thumbs Up to Extreme4x4 for all their help and support.
Now I'm thinking about swapping out the front ones... Wink Defender Puma 2.2 XS 90
Vespa GTS 300
Post #399439 16th Feb 2015 8:01pm
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
Thanks for the update! Thumbs Up
Post #399461 16th Feb 2015 8:57pm
TDCi Guy
United Kingdom 1996 Defender 110 300 Tdi HCPU Auto Keswick Green
@Redzob what's the cost of the progressive springs from Extreme? Tom
@tditomprice
100” Defender Hybrid
2010 Alaska White 90 HT
Post #405919 9th Mar 2015 10:54am
redzob
They were 44 each plus shipping. Defender Puma 2.2 XS 90
Vespa GTS 300
Post #406143 9th Mar 2015 10:15pm
RRUK
Redzob,
Any further updates on the springs and dampers after all this time? Did you swap out the fronts too and if so, what rating are they?
I want to swap out my springs and shocks from standard (90 csw) as I find it so harsh and crashy over even the smallest bumps in the road, it makes it totally unpleasant to live with. 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #486853 30th Dec 2015 12:19pm
redzob
Hi RRUK,
No I never did swap out the front ones. As an update I guess I've gotten used to the 'upgrade' now and am quite happy with the way the landy is set up - I think the Bilsteins in particular make a big difference when cornering as the wallow effect has been significantly reduced.
One point of potential interest - when it went for its 1st service, the mechanic pumped up the tyres to 33 front/38 back (apparently as recommended in the service manual), and the ride was so horrible I asked him what he'd changed. Now I've put them back to about 30 all around, it's back to a much more comfortable ride (and is within allowable limits). Just for reference, these are the std 16" tyres, not low profile 18" etc.
Hope that helps.
Cheers Defender Puma 2.2 XS 90
Vespa GTS 300
Post #486945 30th Dec 2015 5:26pm
RRUK
I'll check mine! 2016 D4 HSE
Post #486973 30th Dec 2015 6:05pm
Anderzander
I've just fitted Bilstein B6 shocks to my 90 and I'm delighted with them. They give such an improved ride - much firmer ride without losing its compliance. 10 out of 10.
Post #486975 30th Dec 2015 6:18pm
pannawonica
Australia
I have just fitted koni heavy track, not cheap however I am well pleased. I find them not as harch as OME but with superior damping. This is compared too as new original. Koni do replacement bushes, or poly whatever. Time will tell if they are going too last, however they are rebuildable.
Post #487203 31st Dec 2015 10:31am
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
Been reading this thread and re-opened it to see if the original posters or anyone else has any updates on standard springs but using either Bilstein or Koni shocks.
I had Koni on my 90tdci, now sold, and I am reviewing options for my 110 CSW. Tempted to keep standard springs and try new shocks before considering changing springs.
Post #531397 13th May 2016 9:48pm
chrisbowler
As an alternative point of view, I have fitted FOX Performance Series Oem fit shocks to my 110 USW 2012 spec defender. They are very reasonably priced, are tuneable and rebuild able and have transformed the road holding and more importantly, when towing, the truck feels much more stable. They were 90 plus vat each corner. I changed the rear springs for mil spec WOLF HS spec rears and am looking to fit SuperPro bushes all round when the Oem bushes give up.
Chris Bowler
Post #531616 15th May 2016 6:28am
mick
England 2010 Defender 130 Puma 2.4 HCPU Rimini Red
I'm on Koni rears fronts going on this week with new standard 130 springs as I've been happy with what's on but seem as they've done over a 100k figured I'd treat it. Whistle
Post #531867 15th May 2016 9:25pm
bm52
Thanks Mick, interesting.
Anyone running a 110 with std springs and B6's on here?
Post #531875 15th May 2016 9:57pm
Page 3 of 4 <1234>
