Home > Tdi > Which TDI Axle do i need
cornish rattler
United Kingdom 1988 Defender 90 200 Tdi CSW Bronze Green
Hi guys
I will soon be buying a disco1 rear axle to fit to my 1988 2.5TD ( 200TDI ) 90 as i want to go to disc's all round and i know about the diff flang's being different to both 200 and 300 axle's but no they can be swapped over but are both axle's a direct fit or will i need to buy a disco 200TDI rear axle Confused Graham
1988 Defender 90 county 200tdi ( Beast )
Paul Walker 1973-2013
( I Almost Had You )
Post #350632 9th Aug 2014 6:37pm
gilarion
I do not think a disco axle is a direct fit you will need to change 3 bolt flange to 4 bolt not forgetting spacer ,and may need to make some fresh brake pipes
Why not just get a Defender axle there are loads about which are a direct fit
Post #350643 9th Aug 2014 6:46pm
cornish rattler
TBH i have only been looking on ebay but all of the defender ones i have seen were drum axle's but there seams to be a few 200 disco axles and a lot of 300 disco / defender axles so just thought i would ask first Smile Graham
Post #350693 9th Aug 2014 11:02pm
Dave T
United Kingdom 1994 Defender 90 300 Tdi SW Cairns Blue
it would need to be a 300 tdi defender though 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #350698 10th Aug 2014 5:43am
cornish rattler
Do you mean if i go for a 300 axle it has to be a defender axle or is the 300 defender axle the only one that will fit my 90 Smile Graham
Post #351007 11th Aug 2014 1:49pm
mikeh501
My 90 200tdi has discovery axles at both ends. Discs on rr obviously.
Post #351051 11th Aug 2014 5:37pm
TDCi Guy
United Kingdom 1996 Defender 110 300 Tdi HCPU Auto Keswick Green
I'd go with 300tdi axles, either defender or discovery as they have the stronger 24 spline shafts. Obviously the flange on the rear diff will have to be changed if you buy discovery axles but that's a pretty easy job. Defender ones should fit straight on.
200tdi defender and discovery axles are only 10 spline and IIRC all defender 200tdi axles have drums.
Post #352109 17th Aug 2014 12:02pm
DOOFER
I just fitted disco 300tdi axles to my 90 drive flange is an easy swap and if you can swap axles I'm sure you can make up some new brake lines. I think you can pick up a cheap flaring tool for just over £10
Post #352111 17th Aug 2014 12:11pm
cornish rattler
Ok 300tdi axles it is then, does it matter if they are A.B.S. axles or none A.B.S. axles as i mite get at least one axle this month hopfully this weekend to pick up next weekend all being well but if i can get a pair cheap enough i will do that Very Happy Graham
Post #352227 17th Aug 2014 10:44pm
cornish rattler
Cheer's guys i have bagged myself one off a V8 disco with A.B.S. sensors so assume its the same as a 300tdi one Smile Graham
Post #354868 31st Aug 2014 11:53pm
jst
ABS makes no odds, Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #354883 1st Sep 2014 6:59am
cornish rattler
Nice one james Thumbs Up Graham
Post #354906 1st Sep 2014 8:16am
cornish rattler
Just an update the disco rear axle is on and gave it a test after we fitted it on Saturday then son and g/friend gave it a proper test and drove it to blackpool and back 110 miles round trip with no prob's and bedded the rear brakes in aswell Very Happy
here are the pic's from removing the old axle to fitting the disco axle
 Graham
Post #364098 13th Oct 2014 10:34am
cornish rattler
Sorry chose the wrong size pic for the last pic Embarassed Graham
Post #364101 13th Oct 2014 10:39am
steventheplumber
England 1987 Defender 90 200 Tdi HT Keswick Green
Hello, question if you dont mind. Did you need anything extra when you changed your axles? regards Steven. Great job Thumbs Up
Post #380634 21st Dec 2014 9:40am
