Home > Tdi > Which TDI Axle do i need |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5111 |
I do not think a disco axle is a direct fit you will need to change 3 bolt flange to 4 bolt not forgetting spacer ,and may need to make some fresh brake pipes
Why not just get a Defender axle there are loads about which are a direct fit |
9th Aug 2014 6:46pm |
cornish rattler Member Since: 31 Aug 2013 Location: Manchester Posts: 642 |
TBH i have only been looking on ebay but all of the defender ones i have seen were drum axle's but there seams to be a few 200 disco axles and a lot of 300 disco / defender axles so just thought i would ask first Graham
1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
9th Aug 2014 11:02pm |
Dave T Member Since: 07 Jun 2013 Location: Glasgow Posts: 490 |
it would need to be a 300 tdi defender though 2015 RRS Autobiography SDV6
1994 Def 90 300tdi |
10th Aug 2014 5:43am |
Do you mean if i go for a 300 axle it has to be a defender axle or is the 300 defender axle the only one that will fit my 90 Graham
11th Aug 2014 1:49pm |
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 |
My 90 200tdi has discovery axles at both ends. Discs on rr obviously.
11th Aug 2014 5:37pm |
TDCi Guy Member Since: 17 Aug 2014 Location: Yorkshire Posts: 286 |
I'd go with 300tdi axles, either defender or discovery as they have the stronger 24 spline shafts. Obviously the flange on the rear diff will have to be changed if you buy discovery axles but that's a pretty easy job. Defender ones should fit straight on.
200tdi defender and discovery axles are only 10 spline and IIRC all defender 200tdi axles have drums. |
17th Aug 2014 12:02pm |
DOOFER Member Since: 07 Oct 2012 Location: Suffolk Posts: 412 |
I just fitted disco 300tdi axles to my 90 drive flange is an easy swap and if you can swap axles I'm sure you can make up some new brake lines. I think you can pick up a cheap flaring tool for just over £10
17th Aug 2014 12:11pm |
Ok 300tdi axles it is then, does it matter if they are A.B.S. axles or none A.B.S. axles as i mite get at least one axle this month hopfully this weekend to pick up next weekend all being well but if i can get a pair cheap enough i will do that Graham
17th Aug 2014 10:44pm |
Cheer's guys i have bagged myself one off a V8 disco with A.B.S. sensors so assume its the same as a 300tdi one Graham
1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) Last edited by cornish rattler on 1st Sep 2014 8:15am. Edited 1 time in total |
31st Aug 2014 11:53pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8065 |
ABS makes no odds, Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
1st Sep 2014 6:59am |
Nice one james Graham
1st Sep 2014 8:16am |
Just an update the disco rear axle is on and gave it a test after we fitted it on Saturday then son and g/friend gave it a proper test and drove it to blackpool and back 110 miles round trip with no prob's and bedded the rear brakes in aswell
here are the pic's from removing the old axle to fitting the disco axle Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Graham 1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
13th Oct 2014 10:34am |
Click image to enlarge Sorry chose the wrong size pic for the last pic Graham 1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
13th Oct 2014 10:39am |
steventheplumber Member Since: 29 Apr 2014 Location: Lincolnshire Posts: 767 |
Hello, question if you dont mind. Did you need anything extra when you changed your axles? regards Steven. Great job
21st Dec 2014 9:40am |
