- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Home > Tdi > Which TDI Axle do i need |
cornish rattler
Hi Steve
The answer to your question is no but if you are changing from a 2.5td / 200tdi axle to a 300tdi / V8 axle you will need to swap the diff flange over from the 200 to the 300 axle, the 300 3 bolt flange can be a pig to get off so we had to bring out the 9" grinder with a cutting disc on it to cut part of the flang off to get to the nut thats behind the flang but other than that everything is the same Graham
1988 Defender 90 county 200tdi ( Beast )
Paul Walker 1973-2013
( I Almost Had You )
22nd Dec 2014 8:47pm |
steventheplumber
Thankyou very much, very helpful. Merry Christmas,Steven
22nd Dec 2014 9:12pm |
