TACK Member Since: 26 Apr 2009 Location: Essex Posts: 1045 ![]() ![]() |
Ian, can take a pic later, but easy enough.
There are 4 bolts which hold the box down, 2 in the cubby box and the other 2 you will see by lifting out the plastic cup holder section. undo these, lift the cubby box out, its nice and light made of MDF ![]() You will see LR have used soft wood timber battens to level the box with the floor pan, these are glued to the underside of the cubby box. I used 2 additional lenghts approx 300mm of 2x1.5" timber, almost like packers, lined them up, drilled holes through the new battens with the holes lined with the cubby box and bolted my new batten to the original holes made by LR in the floor pan, then screwed the cubby box back into my new timber battens, thus raising it up. Simple. Made new holes in the bootom of the cubby box as your old hole alignemnt has been used by the batten, unless you have some longer bolts kicking around ![]() Also gives a secret stash place under the cubby box beacuse there is now a void. Well it was a secret ![]() |
alanhid Member Since: 24 Jan 2010 Location: South Lanarkshire Scotland Posts: 221 ![]() ![]() ![]() |
"What did you do in your defender today"
NOTHING................the wife took it to work! ![]() Def 90td5 CSW xs 2006 |
Hey Tack what do you keep in the Secret place
WarPig Member Since: 04 Dec 2009 Location: Sheffield Posts: 1748 ![]() ![]() ![]() |
Porn mags?? |
Porn mags will fit, but not got mud rails so can't strech legs out ![]() But the utility belt with 300mm dildo fits much better. Or good stash for passports and doc's if overland travelling, might not be so suspect if searched ![]() |
discocuzzy Member Since: 16 Jul 2008 Location: surrey Posts: 1200 ![]() ![]() |
But you have your nice A4 pocket for your training manuals Tony...i recon there should be enough room for "Dorris"...your portable lover.
She can also be inflated from under the passenger seat when you have one of those "it aint gonna suck itself" moments ![]() |
Made a battery clamp to hold the three battery's under the second row seats in place 130's have feeling's as well you know
Three batteries? What you thinking of digging up a corpse and trying to jump start it back into life again? ![]() Treat every day as if it is your last....one day you will be right!! |
You need 2 batteries for welding the other is for the defender.
![]() 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
No the defender already has 2, the 3 are for the 1500w inverter
3WHouse Member Since: 24 Jan 2008 Location: Msk Posts: 70 ![]() ![]() ![]() |
I use the inverter 1500. There are no problems.. http://i058.radikal.ru/1007/50/1a1294b1aa1d.jpg Def`s 90 & 110 Monochrome. You can go fast i can go anywhere.)) http://www.offroadpower.ru/ |
Fitted new stainless steel bonnet hinge bolts..................my first job on it! Life is not a rehearsal!
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
Been busy (what else is paternity leave for?):
Fitted my 2" receiver - very smart. Made a frame for my under-cubby safe to raise it slightly and fitted that - the dogs danglies Fitted my rear parking sensors - a must-have fit for everyone at £20 Stripped my sankey down completely, waxoyled the chassis and bottom of the tub, serviced the brakes, fixed the wiring and painted the tub - bomb proof - it'll outlast me Oh, and had a kid ![]() + New Defender 110 First Edition |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
hi please can you tell me which parking sensors you fitted. Kid - just noticed that, why do you want a baby goat ![]() ![]() thanks BM52 |
