Home > Wheels & Tyres > Dynamic Balancing Beads - Mach 5s
Page 3 of 6 <123456>
K9F
Thanks Wayne, I cannot believe as explained how different the colour is in both the photo and the swatches.
It is in fact pretty close to what is depicted as the slightly lighter shade in the middle here:-
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #344223 10th Jul 2014 11:49am
K9F
Work in progress......
Collected the last two from the powdercoaters and wrapped them up. Just need to wait a while until my current tyres are shot then fit these and then get the other set eventually refurbished.
Post #354383 29th Aug 2014 12:35pm
matus368
mach 5 , where to buy?
Hello guys.
Where do you all buy that nice mach 5 wheel? Many thanks for a link.
Post #361800 2nd Oct 2014 8:40pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Sorry if this is an old thread, I just wondered how you'd gone on with the Magnum beads - do they work?
I have Zu's with 265/75/16 Duratrac's and since I've done a wheel rotation last week I've noticed a definite vibration at certain speeds, can wheels/tyres go out of balance? And if so - surely they will go again, so are beads a good alternative to having to balance every so often?
Post #361825 2nd Oct 2014 9:44pm
K9F
Matus,
Unfortunately they're not made any more, Matt Lee who used to make them was pushed out by cheap copies such as the Challenger Wheel.
Lambley,
Not quite there yet as need to wear out my existing tyres first. Nevertheless there are excellent reports on this thread from people who have used them and it is still my intention to do so.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #361832 2nd Oct 2014 10:18pm
Lambley
Cheers K9
I'm moving to Devon soon so I'll lose the use of a tyre machine at my mates garage so I'm tempted to fit some beads, my Zu's with Duratrac's look like they'll need regular balancing. I'd rather do a 'fit and forget'
Cheers Thumbs Up
Post #361837 2nd Oct 2014 10:27pm
munch90
be nice to know your views on the beads when you try them , I would like know how long after pulling away they get working
Post #361868 3rd Oct 2014 7:19am
K9F
Here you go Munch..... Thumbs Up
http://www.innovativebalancing.com/news.htm
Post #361895 3rd Oct 2014 11:02am
Lambley
Well, I've fitted some beads, 150g bag to each wheel and so far they are very good, no problems to report, seem balanced at all speeds.
I removed all the old weights around the rims (and there were a fair amount), popped the tyre from the rim and dropped in the beads, re-inflated and went for a drive. I gather that now they have found where they are supposed to go to find their balance, they will remain in place, so there is no movement every time I stop, so until they are dislodged they will remain in situ. Came next day from Devon 4x4. So far so good.
Post #364299 14th Oct 2014 5:23am
munch90
sure the beads move each time you stop , roll/fall to bottom then spin out to balance again once moving
Post #364304 14th Oct 2014 5:55am
Lambley
From what I've been told some stick, some don't. They just find their place again when moving, if you want to rebalance and move them, say if you get a clump of mud or stones sticking to the tyre which will obviously affect the balance, then just give them a boot and they will drop to the bottom again. You don't notice them moving, there is no obvious 'unbalance' until you reach a certain speed. I've only done a few short journeys so far so I'm still trying them out.
Post #364310 14th Oct 2014 6:17am
SailingTom
Lambley
Im thinking of going down this route with my wheels that arent currently fitted as the weights dont seem to stick the satin rims.
Can you tell me if there is any noise from them?
Also the only thing im concerned about is ruin the rim on the inside like bead blasting, are they lead with a plastic coating?
Thanks and sorry for the slight hijack, just ive got 305 muds on these sound ideal. Smile Defender puma dormobile camper
Post #364564 15th Oct 2014 6:52am
Lambley
Hi Tom, there seems to be no noise from the beads, I could hear them moving when I rolled them to the car after putting them in, but because they are so tiny they don't make a noise, I certainly can't hear anything when I'm in the vehicle.
They won't affect the inside of the rims at all, they are ceramic, very small kind of hard plastic, maybe only just over 1mm in diameter, all I can suggest is give them a go, maybe talk to Devon 4x4, they advised me on which size and weight would be suitable.
I had between 60g and 100g of stick on weights per wheel before, now there is nothing, just nice and clean.
Post #364585 15th Oct 2014 8:24am
SailingTom
Nice one, think ill have a go with then
Cheers Thumbs Up Defender puma dormobile camper
Post #364586 15th Oct 2014 8:28am
K9F
Read the link I put up for Munch most questions are answered therein. None of the beads will stick that is the whole concept of dynamic balancing. Each and every time the beads will naturally take position where they are needed to maintain the dynamic balancing of the tyre and wheel combination for the duration the tyre remains fitted. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #364650 15th Oct 2014 12:56pm
