Home > Wheels & Tyres > Dynamic Balancing Beads - Mach 5s
Page 5 of 6 <123456>
K9F
Thanks Ken,
Your ability is unquestionable. Thumbs Up Bow down
Unfortunately my tyre fitter (an old school mate of mine) is very, very busy and cannot afford to dedicate the time desired to sort mine out. (I don't really like to ask either as I can see how busy he is) Thank you for your kind and generous offer and if you were nearer I would take you up on it. Having heard good things about the beads and spoken to them twice with the 'warranty' given I have nothing at this juncture to lose apart from the time it will take me to do two trips to get the new tyres fitted as I have got the beads already. I also have warmed to the concept of the dynamic balancing theory. I shall see this week and report back. On my existing Mach 5s I have at least 6" of stickies on the inner edge on all four. These I feel are going to be a ba5t4rd to remove eventually. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #407759 15th Mar 2015 2:04pm
Hot air gun will assist with that Thumbs Up
Post #407947 16th Mar 2015 8:45am
K9F
Top tip thanks. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #407952 16th Mar 2015 8:55am
K9F
Tyres ordered last thing Friday delivered today first thing.
Had a bit of a nightmare getting them fitted due to one of the tyres having collapsed walls from storage and not beading on the rim. As luck would have it (or not) the fitter concerned struggled to fit the very first one, gave up and lost interest in fitting the remaining four so took the lot and went elsewhere. Took them to the Cooper Tyre dealers in Poole who fell over themselves to assist. White letters in this time.
Laughing
Dynabeads duly fitted, will try and get these nailed on today. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #408393 17th Mar 2015 2:19pm
Venomator
Looking good MAl... Thumbs Up
You've gone for Muds though - be interested to know what road noise they generate... Whistle
 Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #408396 17th Mar 2015 2:22pm
K9F
Thanks Venomator.....Can't possibly be any worse than the Coopers, I had to upgrade the HU and buy a subwoofer for them mothers.
Not tried them out yet but got them fitted to the Landy, also had the foresight as the wheels were coming off to source some Dinitrol and redo as much as was practical under the arches at the same time....
Not as 'prominent' as the 15" X 11.5" and on the right side of legality this time. Thumbs Up
Just the spare to fit. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #408398 17th Mar 2015 2:23pm
Thumbs Up
What exhaust have you got on there mate?
Post #408502 17th Mar 2015 7:35pm
K9F
Off Topic
Made by a horse dentist......Griffin....316 stainless, lifetime warranty with 'self designed and adapted' decat to include a cat of sorts. Straight through centrebox and no rearbox......
Several forum members have them, Oakseywick, Sticky and Harryb450 to name a few, good value for money. From an old thread..... Thumbs Up
K9F wrote:
I too have a Griffin, decat and no backbox system on my 08 Puma. Lifetime no quibble warranty and has given me excellent service. Do a search on here under 'horse dentist.' There are differing opinions but ultimately the prices vary considerably. How deep are your pockets and hoe much do you want to spend on it?
Post #408506 17th Mar 2015 7:51pm
K9F
Done and dusted.......
Took the 90 for a long spin today at varying speeds upto a short blast above where I should have been 'perhaps?' There is a very slight vibration only discernable when the steering wheel is not being gripped tight (not on the vehicle itself ) bang on at 50mph. At all other speeds with regards to vibration etc, it was impeccable. I am currently running at the pressures applied by the tyre fitting centre which is 36psi all round. I will drop the pressures perhaps and see what occurs. Nevertheless at this juncture I am more than happy that I chose the balancing bead route and will probably bin the stickies and fit a second lot to my other set of Mach 5s. I note Lorryman and Lambley had issues a while after fitting. I'll get back if I find the same.
As a footnote the BF Goodrich KM2s are significantly quieter than the Cooper Discoverer STTs.
Post #408810 18th Mar 2015 7:54pm
Looks nice mate, almost looks like the spot filters and wheels are colour coded. Rolling with laughter
Thumbs Up
Post #408816 18th Mar 2015 8:20pm
K9F
Mild OCD......They are Steve! Shocked Embarassed Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #408822 18th Mar 2015 8:44pm
SailingTom
I wouldnt be surprised if the patriot writing were to change to blue aswell now! Smile
Post #408861 18th Mar 2015 10:38pm
K9F
Now there's a cracking idea Tom. Thank you, weekend job. Very Happy Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #408901 19th Mar 2015 8:19am
No such thing as OCD its CDO Whistle
Post #408903 19th Mar 2015 8:24am
K9F
Dropped the pressures 32 front, 34 rear and everything sweet. Thumbs Up
Decided to clean the old Mach 5s and used Ken's trick to get the stickies off (thanks again Ken). They came up a treat and the powdercoating is still fine after just over 5 years. Will go down the balancing bead route with these as well if they ever go back on.
A lot of the weights literally needed no effort to get off, some where already missing and others were more stubborn. Nevertheless I was shocked by how many there were. These were from two wheels only, had turned black and some had evidence of corroding.
Post #409330 20th Mar 2015 6:32pm
