Home > My Defender > What Did You Do In Your Defender Today |
david mitchell Member Since: 01 Jul 2012 Location: Meath Posts: 418 |
Visited the national ploughing championships and saw the following
25th Sep 2014 10:52pm |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
Fitted new rear mudflaps (Bearmach,£13 for 2 delivered ).FYI.6.5mm drill bit to get the riv-nuts out then bolted the new un's back in.See how long they last. Pov.spec,ftw. 2006, 110,TD5.
26th Sep 2014 11:02am |
I lost a front mudflap at the end of July, not so much lost it, it just gave up and fell off on an off road site. No problems I thought, I'll put the other one on as I bought a pair a couple of years ago and the one that broke was the other. I got home, looked in the garage and laid my hands on the second, even though it was still in its plastic bag it had cracked open along the slight crease where it had sat on a shelf for two years. Yes, the colour of the bag was blue
I had noticed on one of the roundabouts in town at the end of June that there was a front mudflap from a Defender sat on one of the little filter islands before the main roundabout so the next time I went to town I made my way to the island and it was still there! So two months after I'd first spotted it I picked it up, all that had happened was the metal bracket had broken off, the mud flap was fine and an original LR one, so fixings cut off and it's now fixed to mine. So even with a 2 year warranty, a certain company's products can still only last that long while sitting on a shelf! |
26th Sep 2014 11:22am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20499 |
Following on from my thread the other day finished this off today with a bit of Dinitrol.
Made the bracket from scratch, wired in the socket and sealed it properly and carefully greased inside. Just left the very small drain hole open on the very bottom. Click image to enlarge As you can see it's got LED tests ligts on it which is useful. The example in the photo is the hazard flash. Also added another extra earth and its cured my issues on dash. The trailer light flash keeps up with the indicator flash on the dash nearly exactly the same time now where it was lagging. Also had 0.26 resistance in the earth as standard which obviously was not helping and now it's about 0.1 as it's got a twin earth now. |
26th Sep 2014 11:37am |
Yeah,I'm not holding my breath tbh,just couldn't resist the price,lol. Pov.spec,ftw. 2006, 110,TD5. |
26th Sep 2014 2:42pm |
Venomator Member Since: 25 Aug 2014 Location: Peterborough Posts: 2087 |
Have been really unhappy advertising for nowt with a branded spare wheel cover...
Sorted that today... Click image to enlarge And while I was messing with my back end, fitted some pretty nifty plug 'n play LED stop & tail units... Click image to enlarge Much happier bunny with my prettier (and more visible at night) rear end now... Rog... The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
26th Sep 2014 6:33pm |
Those are Wipac's aren't they?
Try and get the rest, the LED lights are really good. I have the RDX's one's and they are excellent. |
26th Sep 2014 6:46pm |
They are indeed Wipacs and excellent value for the price...
Just about to press the button on the indicator jobs from FlatDog for similar money per unit... Rog... The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
26th Sep 2014 6:51pm |
I'm sure the Wipac lights are good but I'd recommend you go for the RDX indicator relay.
Not saying this just because it's what I have but generally it's thought of as the better option for the relay due to the trailer light side of things. The RDX relay does eactly what it claims to do, I tow on a regular basis and it works for that as expected too. |
26th Sep 2014 7:35pm |
Thanks for the pointers Steve, I think...
I have just ordered the indicator set and RDX relay from BoB... Appreciate your advice based on experience... Rog... The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
26th Sep 2014 9:11pm |
Two options are either RDX lighting set and RDX relay or Wipac light set and RDX relay. Either option you will be pleased. |
26th Sep 2014 9:23pm |
I went for RDX for both... Rog... The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
26th Sep 2014 9:26pm |
Stickleback Member Since: 20 Jun 2014 Location: West Yorkshire Posts: 93 |
So, today have booked car in at Simmonites for LEd lights, upgraded bulbs in headlamps, swing-away rear wheel carrier, new sporty steering wheel, and most importantly, WAXOYL treatment.
Hopefully truck will last longer now and also see/be seen when its dark. On the way back, called at local car handwash, and got car washed. can confirm car leaks from around drivers door window seal and the passenger side door seal just about everywhere. I actually got wet sat in the car when the guy was pointing the pressure jet at the passenger door. Ho hum... just normal I guess. |
27th Sep 2014 11:45am |
Inigo Member Since: 13 Nov 2011 Location: Kent Posts: 617 |
Finally (as in 3 years later) managed to fit my spotlights (as it needed A bar, which needed winch bumper and winch, etc).
27th Sep 2014 12:45pm |
