Home > Puma (Tdci) > Intermittent indicators
DavidS
United Kingdom 2011 Defender 110 Puma 2.4 USW Stornoway Grey
Really frustrating indicator problem where the indicator stays on every so often instead of flashing.
is it just shy?, or is the problem switch or bulb related usually? 2 LandRovers, and counting!
Post #358695 18th Sep 2014 3:29pm
K9F
Relay would be my first port of call. Switch only likely if it wasn't cancelling looking at the diagram. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #358699 18th Sep 2014 3:48pm
ParabolicSwivel
My MY12 Has done this twice in the last 6 months. Thought it was just me! No idea why so I'd also be interested to hear any suggestions. It's surprisingly tricky to simulate the flash when it happens by waggling the indicator stalk at even intervals...
Both times they started to behave again immediately after switching the engine off and re-starting it. Not such an easy solution if you only realise they're not working as you indicate to join the main carriageway of a motorway! I was hypothesising that it might be related to the immobiliser/alarm.
It's not done it to me in about 6 months now.
I mentioned it to the dealer at the last service but they misunderstood and the technician apparently thought I was talking about the self-cancelling mechanism so didn't do anything about it. Didn't have the energy to take it in again to take another look.
Post #358701 18th Sep 2014 3:55pm
DavidS
Cheers I will have a look later on. 2 LandRovers, and counting!
Post #359216 21st Sep 2014 11:33am
grafty99
My td5 did this, turned out to be the corrosion in the connector block for the towing electrics from the main loom. Off side rear arch Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #359261 21st Sep 2014 5:12pm
miket
Mine did this, or at least the RHS indicators did, and it turned out to be due to water getting in behind the dash (probably from the roof, which was unexpected).
Who'd have thought it from a Defender...
Post #359305 21st Sep 2014 8:04pm
DavidS
I have realised that I may need a bigger toolkit for my Defender ownership 2 LandRovers, and counting!
Post #359646 23rd Sep 2014 8:04am
DavidS
Just an update, it was indeed the relay. Thanks for your help all fixed again. 2 LandRovers, and counting!
Post #365166 17th Oct 2014 9:45am
