![]() | Home > Puma (Tdci) > Intermittent indicators |
Relay would be my first port of call. Switch only likely if it wasn't cancelling looking at the diagram.
![]() Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 18th Sep 2014 3:57pm. Edited 1 time in total |
ParabolicSwivel Member Since: 13 Nov 2013 Location: Hertfordshire Posts: 42 ![]() |
My MY12 Has done this twice in the last 6 months. Thought it was just me! No idea why so I'd also be interested to hear any suggestions. It's surprisingly tricky to simulate the flash when it happens by waggling the indicator stalk at even intervals...
Both times they started to behave again immediately after switching the engine off and re-starting it. Not such an easy solution if you only realise they're not working as you indicate to join the main carriageway of a motorway! I was hypothesising that it might be related to the immobiliser/alarm. It's not done it to me in about 6 months now. I mentioned it to the dealer at the last service but they misunderstood and the technician apparently thought I was talking about the self-cancelling mechanism so didn't do anything about it. Didn't have the energy to take it in again to take another look. |
DavidS Member Since: 14 Apr 2014 Location: North East Posts: 55 ![]() ![]() ![]() |
Cheers I will have a look later on. 2 LandRovers, and counting!
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4796 ![]() ![]() ![]() |
My td5 did this, turned out to be the corrosion in the connector block for the towing electrics from the main loom. Off side rear arch
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
miket Member Since: 05 Oct 2012 Location: Peak District Posts: 143 ![]() |
Mine did this, or at least the RHS indicators did, and it turned out to be due to water getting in behind the dash (probably from the roof, which was unexpected).
Who'd have thought it from a Defender... |
I have realised that I may need a bigger toolkit for my Defender ownership 2 LandRovers, and counting!
Just an update, it was indeed the relay. Thanks for your help all fixed again. 2 LandRovers, and counting!
