Home > Puma (Tdci) > Running on/throttle responce?
Page 2 of 3 <123>
Ads90
United Kingdom 2007 Defender 90 Puma 2.4 CSW Keswick Green
I have an '07 model and don't recognise this symptom - although because I bought it 2nd hand, the previous owner may have had it fixed?
Post #3587 1st Sep 2008 9:26am
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
Thanks mate.
This is really giving me hope.
Once the vehicle broke down at my work. Nice man came from LR Assist after he sorted the problem on his laptop I asked him to give it a try accross the yard. I told him the symptons and off he went, after nearly hitting one of our 80t trailers he gave me the keys back and said..... "I don't care what the dealers have told you, that ain't right". He even put it in his breakdown report and then had it recovered as he said it was not safe to drive. Not that it did any good Rolling Eyes
Post #3588 1st Sep 2008 9:39am
Ads90
That sounds very wrong - and scary!
With the cramped driving position (I'm long of leg) it's hard enough going quickly from gas to brake - I'd definately notice if the revs were picking up (or not dropping) as I do this, and I can say they drop more-or-less just like any other car I've driven. The characteristics are indeed different, but nothing that driving for a few hundred miles didn't allow me to adapt to...
Post #3589 1st Sep 2008 9:49am
The Boy
I have sort of got used to it but it still catches me out in traffic now and then Shocked . If it can be fixed then I hope my mpg will also improve?
Post #3590 1st Sep 2008 10:12am
Ads90
Can't think that fixing it would make mpgs any worse... it should involve cutting the fuel a tiny bit quicker.
Might not be enough to notice though.
You've probably read the mpg thread - and have an idea of what you should be getting, depending on your driving style and loads? I'm still averaging 30, with very mixed length, lightly-laden journeys - this kind of tells me everything is probably working as it should!
Post #3591 1st Sep 2008 11:08am
The Boy
Yes mate read that with great interest. The first six months it was quite good around the 27 mark with the roof rack ect but since I have been having all the problems I stuggle to get more than 24 on motorways (65mph) and other driving gets around 18-21. I do want to have more work done to it but I don't want to spend any more money until it is right.
Post #3592 1st Sep 2008 11:17am
Ads90
I'd agree that 27 with a rack sounds about right - especially with some etcs!
But 18 to 21 doesn't seem right - I used to get that with my V8 90.
I suppose with a laden rack, and maybe towing, with a headwind, but not just normal stuff.
It's a tricky one, especially when your garage is telling you there's nothing wrong!
I don't know what to say, other than to try 2nd opinions (from independants). It's all money though. Confused
But if you get back up to 27+ I suppose you'll recoup some in the long run.
Post #3595 1st Sep 2008 1:33pm
The Boy
My hope is that this guy from Lodge Lane will have more knowledge than the dealer technicians and be able to identify the problems, and even fix them. My worry is that if it is a problem LR know about but can’t fix then I am in for more waffle!!!
Post #3597 1st Sep 2008 2:32pm
jst
the early ones we had at work used to run on a bit the latter ones dont so it seems the 08MY have the issue fixed. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #3605 1st Sep 2008 6:53pm
The Boy
Thanks James
I really do hope this is fixable Thumbs Up
Post #3606 1st Sep 2008 7:05pm
philp
2008 Defender 90 Puma 2.4 HT Tonga Green
I have this problem as well, and my 08 Defender was becoming un-drivable, I checked the switch on the clutch master cylinder and discovered it had failed open.
After an LR assistance Technician "linked out " the connector to the clutch switch closing the circuit it drove fine no run on at-all,I booked the car in at the local Main Stealer for a new clutch switch.
I've had the car back for 3 days now and although not as bad, the engine still runs on a bit when changing up or down a gear causing a lot of noise from the transmission when changing up.
The LR bumph on the clutch switch is that it is used to activate "surge damping"by stopping the engine speed rising dramatically, giving a smoother gear change.
The operation of this switch is normally open- (open circuit when clutch is at rest) and closes when you depress the clutch.
I would be interested if linking out this switch affects the engine power/torque as well, I couldn't really notice it.
Post #9630 11th Apr 2009 2:38pm
Edd80Inch
United Kingdom 1999 Defender 90 Td5 HT Rioja Red
DefenderKen wrote:
April 08 build and mine does not do this.
I've had a few 'fly by wire' cars now including a mkV golf gti which do have a different 'feeling' to good old fashioned cables, however my car does nothing like you are describing.
Hope this helps.
April 08 build and my 90 does this, not right and I will ask the dealer to look at it.
Edd 1999 90 TD5 County
1943 Ford GPW Jeep
Post #9645 11th Apr 2009 10:42pm
philp
I prefer driving my TDCi with the surge damping disabled (connector linked with jump wire).
But I shall leave it as LR intended to avoid any Guarantee problems,although one of my neighbours has decided to run his with the switch linked out.
I also have a 2004 TD5 Defender 90, this has the surge damping as well but it actually works and doesn't over rev when changing up.
Post #9648 12th Apr 2009 8:57am
AndrewS
Well I took the Red Dwarf into my dealers with this overrun problem. I came back fixed Thumbs Up Oh hang on the overrun issue was sorted. I will ask my dealer what they did.
Post #9657 13th Apr 2009 9:22am
sasha2001
Russia 2008 Defender 110 Puma 2.4 CSW Tonga Green
Feb 08 build and does not do this
Post #9665 13th Apr 2009 7:21pm
Page 2 of 3 <123>
