Home > Technical > Td5 air con - where's the heat?
Jeremy
So the air con works brilliantly at cooling but I can't seem to get any heat out of it. What obvious solution am I undoubtedly missing??
Post #357816 14th Sep 2014 5:02pm
Cupboard
The heater is separate.
The bit you hit your knees on only does cooling, the heating is controlled by the levers round the dash. On the left you've got the fan controls, on the right you've got controls for where the air goes and how hot it is.
Post #357819 14th Sep 2014 5:08pm
Jeremy
So turn the aircon off to use the heater?
Post #357831 14th Sep 2014 5:53pm
landy andy
Yes. Air con and heater are two completely different things.
Andy
Post #357851 14th Sep 2014 6:44pm
jimbob7
You can't have the heater on at the same time as the A/C inna Defender,really??The only useful thing about a/c inna td5 is demisting the windows....so I thort,lol. Pov.spec,ftw. 2006, 110,TD5.
Post #357889 14th Sep 2014 10:01pm
Mjibex
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Loire Blue
On a td5 the aircon, a stand-alone unit, will only cool the air. You can run heater and aircon (on lowest setting), to help dry the air.
Tdci you can have hot air conditioned air.
Post #357993 15th Sep 2014 12:27pm
Jeremy
Again, thanks for the guidance.
Post #358073 15th Sep 2014 7:27pm
RoadForce
Netherlands 2000 Defender 130 Td5 HCPU Coniston Green
A bit off-topic perhaps (my car came without user manual), but: are there any setting combinations on the aircon dials I should avoid? E.g. having the 'blower' dial on position I and the 'cooler' dial on III? Or even the cooler on MAX whilst the blower is turned off? Defender 130 HCPU Td5 MY2000
Post #358159 16th Sep 2014 8:58am
Gareth
I usually leave the ac on fan position 1 all year round,and the cooling power on 3 in summer, 1 in winter. you can turn off the dash vents. There are enough gaps around the system to allow it to dry the air without causing a draft! Its a basic and primitive system, but it works well on my 90. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
1968 S2a 88 aka Bob
2014 Jaaaag F Type 3.0 Supercharged.
Post #358243 16th Sep 2014 5:23pm
RoadForce
Thanks for that Gareth, my dash vents don't do much anyway as my blower is quite anemic (for which I opened a separate topic). Defender 130 HCPU Td5 MY2000
Post #358308 16th Sep 2014 8:48pm
