Home > Technical > Td5 air con - where's the heat? |
The heater is separate.
The bit you hit your knees on only does cooling, the heating is controlled by the levers round the dash. On the left you've got the fan controls, on the right you've got controls for where the air goes and how hot it is. |
14th Sep 2014 5:08pm |
Jeremy Member Since: 26 Aug 2014 Location: Surrey Posts: 33 |
So turn the aircon off to use the heater?
14th Sep 2014 5:53pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5707 |
Yes. Air con and heater are two completely different things.
Andy |
14th Sep 2014 6:44pm |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
You can't have the heater on at the same time as the A/C inna Defender,really??The only useful thing about a/c inna td5 is demisting the windows....so I thort,lol. Pov.spec,ftw. 2006, 110,TD5.
14th Sep 2014 10:01pm |
Mjibex Member Since: 21 Mar 2013 Location: Reading Posts: 283 |
On a td5 the aircon, a stand-alone unit, will only cool the air. You can run heater and aircon (on lowest setting), to help dry the air.
Tdci you can have hot air conditioned air. |
15th Sep 2014 12:27pm |
Again, thanks for the guidance.
15th Sep 2014 7:27pm |
RoadForce Member Since: 17 Jul 2014 Location: Holland Posts: 335 |
A bit off-topic perhaps (my car came without user manual), but: are there any setting combinations on the aircon dials I should avoid? E.g. having the 'blower' dial on position I and the 'cooler' dial on III? Or even the cooler on MAX whilst the blower is turned off? Defender 130 HCPU Td5 MY2000
16th Sep 2014 8:58am |
Gareth Member Since: 12 Dec 2011 Location: Bramhall Posts: 1102 |
I usually leave the ac on fan position 1 all year round,and the cooling power on 3 in summer, 1 in winter. you can turn off the dash vents. There are enough gaps around the system to allow it to dry the air without causing a draft! Its a basic and primitive system, but it works well on my 90. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy 1968 S2a 88 aka Bob 2014 Jaaaag F Type 3.0 Supercharged. |
16th Sep 2014 5:23pm |
Thanks for that Gareth, my dash vents don't do much anyway as my blower is quite anemic (for which I opened a separate topic). Defender 130 HCPU Td5 MY2000
16th Sep 2014 8:48pm |
