Home > Maintenance & Modifications > Wipac LEDs flashing speed
ronwong
2012 Defender 110 Puma 2.2 SW Orkney Grey
I just replaced all my lights to led, now signal and hazard lights flash very quickly, just like how usually it goes when you have a blown blub. I thought it's plug and play? Did I do something wrong?
Post #355858 5th Sep 2014 10:40am
munch90
you need to change the flasher unit to a led electronic one , easy to do just remove old one and fit new one , 30sec job
or fit resisters to the lamps , longer job and not as easy as replacing flasher unit
Post #355862 5th Sep 2014 10:53am
Jim_Bean
Post #355869 5th Sep 2014 11:46am
Wangers
United Kingdom 1995 Defender 110 300 Tdi CSW Aintree Green
If a bulb Blows then there is a loss of resistance hence the rapid flash.
LED drawes less in the first instance so unit thinks there is one blown.
Either need to put in resistors to each bulb or change relay. TY&GN
10 years in a WOLF, WIMIK and Snatch and this is all I have to show!
Post #355946 5th Sep 2014 7:46pm
Post #355951 5th Sep 2014 7:49pm
