Home > Tdi > me heeds off!! opinions please
Page 2 of 3 <123>
nickhodgson
Did the head gasket repair fix your coolant loss problem?
Looking at the picture of your radiator I would have concerns about it. Did you do a pressure test on the coolant system?
Regards
Nick 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C
2000 300tdi Defender 110 P/UP
2015 Discovery 4 SDV6 HSE
Post #352659 20th Aug 2014 8:22am
g-mack
not 100% sure yet! as i have had a few teething probs after going back together. it HAS been losing water,BUT!! i discovered a rad hose not fully tightened and dripping! and it HAS been smoking BUT! this time it is dirty grey smoke, and discovered a leak-off banjo had worked loose allowing air in and out!. Also not done enough miles yet to say for def if its cured it, but it is looking good so far!! My 109 thread
my youtube channel
Post #352672 20th Aug 2014 9:37am
g-mack
Argggggggggg head gotta come off again!!!
so one of the on going niggles was the booming noise at certain revs, been through everything possible and it looks like its a Valve related issue. either play in tappets, bent rod, wear on rocker, bent valve, sticky valve, non sealing valve or weak valve spring!! phew.
to top it off whilst driving home last night noticed at traffic lights plumes of steam from exhaust again!!
so i have a spare head, im gonna put on this week. but this time before head goes on i will check for any play in cam followers and replace if necessary. not going to expense of replacing any other components on new replacement head just gonna hope its ok. if not then i will have to bite the bullet and buy a new head!! 360 quid i aint got!! My 109 thread
my youtube channel
Post #353758 26th Aug 2014 1:45pm
Phil c
sounds like you having as much fun as I was when my cam shaft key way chipped and my truck was off the road for about 3 months wile I was waiting for time to get it all back together. with your replacement head it might be worth getting a valve spring compressor and dropping all the valves out and changing the valve stem seals and regrinding and seating the valves back into the read, that way you can eliminate sticky valves ets.
Post #355020 1st Sep 2014 8:57pm
munch90
what did you find when the head was off 2nd time , did you cure the noise ?
Post #355023 1st Sep 2014 9:08pm
g-mack
UPDATE: spent best part of ten hours changing head AGAIN Evil or Very Mad replaced with a used head that had a recent skim and p test.
its now running like a bag of hammers!!!! sounds like its only running 2 or 3 cylinders! My 109 thread
my youtube channel
Post #355734 4th Sep 2014 8:29pm
munch90
mmm not so good is that ?
did you find anything on the old head ?
did all the tappets adjust roughly the same just in case it's lower down like cam or follows ?
Post #355738 4th Sep 2014 8:36pm
g-mack
only adjusted 4 of the valves rest were spot on! My 109 thread
my youtube channel
Post #355742 4th Sep 2014 8:44pm
g-mack
had a good look at cam followers, and brass guides all seemed ok with no play in them My 109 thread
my youtube channel
Post #355743 4th Sep 2014 8:46pm
munch90
if its down on cyls for sure , crap in injectors ?
Post #355758 4th Sep 2014 9:04pm
shaggydog
Blead Injector pipes?
Checked timing?
Post #355766 4th Sep 2014 9:25pm
g-mack
injectors is what im thinking. dont think its the injectors themselves though. have to fess up to something!!!
as i was tightening number 2 injector retaining nut the stud snapped! even though i was using recommended torque! luckily i had a spare injector stud. when i put it in im nor sure the stud went all way in!! i dropped injector in and tightened it all up. im hoping this may be causing the injector not to seal properly!! My 109 thread
my youtube channel
Post #355769 4th Sep 2014 9:30pm
munch90
just run it and spray soapy water round the injectors to see if any blowing bubbles
Post #355772 4th Sep 2014 9:37pm
g-mack
OK not injectors !cracked each one off and no3 cylinder made no difference to running. so my problem is no3
this is dragging on now think im gonna break out the credit card and give turners a ring Crying or Very sad My 109 thread
my youtube channel
Post #355866 5th Sep 2014 11:29am
munch90
you say its not injectors but is the injector injecting as just because its getting diesel doesn't mean its working
I take it no3 was getting diesel ?
if so swap say no2 and no3 injectors and check if missing moves to no2 , that should rule out injector and if injection pump is giving pressure to no 3
if no2 misses then got to be injector
if no3 still misses its got to be either injection pump not giving pressure to no3 or valves then you need to do a compression check or better cylinder leakage check
cyl leakage check will tell you if its valves and which one (in or ex ) and if its piston problem
on dodgy injector check small spill return pipe to sure diesel isn't just passing through , should only get a small amount from return pipe , maybe worth checking against one of the other injector
BE CAREFUL WHEN WORKING ON INJECTORS , AS THE HIGH PRESSURE CAN INJECT THROUGH YOUR SKIN
Post #355872 5th Sep 2014 11:49am
Page 2 of 3 <123>
