Home > Tdi > me heeds off!! opinions please
Page 1 of 3 123>
g-mack
long standing issue with coolant loss and white smokey zorst.
decided to take the head off to investigate as everyone seemed to be pointing to gasket failure.
now when i removed the intercooler to inlet pipe it was quite wet in there! couldnt tell if it wasa coolant but it was definitely more than just oil!
so when the rocker cover came off, there was a fair bit of coolant in the rocker!!!
anyhoo head is now off and the gasket looks fine! zort ports are nice and sooty so coolant not been washing down them.
here are some pics, no cleaning has been done, pics taken as things came off!!
 My 109 thread
my youtube channel
Post #347025 22nd Jul 2014 6:22pm
shaggydog
Silly question but has it rained recently?
How is the oil? does the oil show any white emulsified oil in it from mixing with coolant?
There shouldn't be any coolant at all in the rocker cover as it doesn't have any coolant point in it.
However it could indicate that there is a crack in your head which when running opens up and has allowed coolant from a coolant gallery into the rocker cover.
Do you have access to a endoscope? Might be worth poking it down all the passages and looking for hairline cracks. You would be amazed how small a crack can leak when under pressure.
The head gasket also looks quite new so perhaps it has had similar problems in its past life?
On the plus side, your bores look beautiful, still clearly see the honing marks so that looks sound Thumbs Up
Post #347031 22nd Jul 2014 6:38pm
Retroanaconda
Coolant and oil can also mix in the radiator, if there is a split between the water and oil sections.
Post #347032 22nd Jul 2014 6:43pm
shaggydog
/\/\ Very good point.
Get your dipstick out Whistle
Post #347034 22nd Jul 2014 6:46pm
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
Its been a while since I gazed into a 300tdi lump - ah the memories!
Post #347039 22nd Jul 2014 7:05pm
g-mack
actually yea it chucked it down a few days ago! lol
oil looks perfect! Thumbs Up can the coolant make it's way up the valves?
ive been informed by someone in the know that cylinder 4 is passing gas !! fire ring should be clean all way round!
so im gonna clean surfaces check tolerances for warping and bung it back on!!
im hoping this might also be my booming sound under load! My 109 thread
my youtube channel
Post #347046 22nd Jul 2014 7:29pm
munch90
id go with no 4 , doesn't like quite right
I think if I remember right when I done a few it was always at the back of gasket as well
Post #347058 22nd Jul 2014 7:54pm
g-mack
yep no 4 would be correct Thumbs Up My 109 thread
my youtube channel
Post #347092 22nd Jul 2014 8:59pm
munch90
if you get it faced , make sure they take the minimum off
some places will just set machine to surface say 5-10 thou first cut to save time
get them to do cut 2 thou first cut or less
that's if it needs it , if it has not got hot it may be ok
Post #347099 22nd Jul 2014 9:09pm
g-mack
im hoping its ok! it hasnt over heated Thumbs Up will find out tomorrow! My 109 thread
my youtube channel
Post #347117 22nd Jul 2014 10:15pm
g-mack
so today was cleaning and prepping surfaces and checking head for warping.
thankfully after a thorough going over with the feeler guauges, the head is NOT warped and within tolerance. phew Thumbs Up
head cleaned & prepped
block deck
Also dropped th oil today, not a bit of coolant to be seen in there!
 My 109 thread
my youtube channel
Post #347243 23rd Jul 2014 5:19pm
g-mack
while i had it in bits, i decided to remove inter cooler aand associated pipes and separator for a good cleaning in paraffin.
Also drained coolant from rad and heater matrix and gave them a good flush!
 My 109 thread
my youtube channel
Post #347697 26th Jul 2014 1:52pm
g-mack
finally all back together after waiting for a few odd parts. nearly 3 weeks off the road ouch!
started after 4 turns AND i didn't charge batt while it was off so batt seems to be fine.
can anyone help me understand the cooling system?
rad, engine and H matrix were all emptied and flushed. followed rave on refill procedure.
but what i want to know is this: is the engine running without ANY coolant until the stat kicks in to let water into engine? OR is it the other way round. when i fill the system coolant can naturally get into the engine jacket and the stat lets it out? im expecting the header to drop as ive only put 10 ltrs in and it takes 11, also havent had stat kick in yet cos the bloody thing doesnt want to get any hotter than 71 deg!!! (think stat opens at 77deg)
it just feels wrong letting engine get so hot with no coolant in the block.
thoughts??? My 109 thread
my youtube channel
Post #349920 6th Aug 2014 12:19pm
g-mack
forget that question about coolant! rave has answered me Thumbs Up My 109 thread
my youtube channel
Post #349925 6th Aug 2014 12:54pm
jst
if you didnt drain the block there may still be some old coolant in there hence feeling short by 1L
wpump circulates it around lump, when stat opens it allows greater flow through the rad. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #349926 6th Aug 2014 12:57pm
Page 1 of 3 123>
