Home > Td5 > Disco transfer box on TD5 |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000 |
Only thing to look out for is that not all td5 Disco's had a locking diff.
Google will turn up lots of info on it - and Ashcrofts web site will tell you which serial numbers are affected. Stephen |
19th Aug 2014 6:14pm |
Derrickthedefender Member Since: 28 Jan 2014 Location: South Posts: 294 |
Ah nice one, I'll have a look now A Defender... Mans best friend, never judges, trustworthy (most of the time), go anywhere, do anything, looks the business, and mans biggest money pit!!!
Yes the name for my 90 is Derrick! |
19th Aug 2014 6:15pm |
Shutts Member Since: 10 Aug 2014 Location: Tiptree Posts: 52 |
I may have a disco 300 tdi transfer box available if you decide to do it.
Shutts |
19th Aug 2014 6:44pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6098 |
Disco t/box is 1.2:1 your current defender one should be 1.4 I've done it to mine. makes a lot of difference. if yor engine is in standard tune it might struggle when towing/hill starts/running bigger tyres, especially when pulling away, but once up to speed it's pretty good. |
19th Aug 2014 6:53pm |
Ah yes my mistake, I'm hoping to run 1.222 A Defender... Mans best friend, never judges, trustworthy (most of the time), go anywhere, do anything, looks the business, and mans biggest money pit!!!
19th Aug 2014 7:09pm |
Shutts, will that run on 1.222? A Defender... Mans best friend, never judges, trustworthy (most of the time), go anywhere, do anything, looks the business, and mans biggest money pit!!!
19th Aug 2014 7:10pm |
kevinf Member Since: 12 Apr 2011 Location: sheffield Posts: 55 |
Did the same mod to my 52 plate 110 a few months ago, I bought my transfer box off eBay, then found that my original transfer box has two switches fitted to it 1 for the diff lock warning light and the other I assume is to tell the ecu that low range as been selected but the one I bought only had 1 switch fitted and that was a different size so in the end I had the internal bits fitted to my original case, so bear that in mind when you get your new transfer box
19th Aug 2014 8:43pm |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 |
Best mod I've done on my Td5 90 by far.
Mine has got a bit more grunt than std but I'm sure you'll be fine towing and on hills etc. I know what diesel Jim is saying about towing and hill starts but then again first was pretty useless before anyway, it's much better now for me anyway, you soon get used to it. I had to swap over my handbrake drum etc as the disco one was slightly deeper and wouldn't have fit, plus the speedo sensor is different but they're both dead easy to do, I can't remember about the switches etc but everything works as it should apart from the light on the dash doesn't come on when diff lock is engaged, but I'm sure I'd know if it was in diff lock anyway!!! Make sure you buy 2 new seals before fitting, they are only cheap and tend to get damaged when removing them, prob about £3 for both. If you can find a decent one then just give it a go and keep yours with all the bits, then you can always go back again if you don't like it, but you will! |
20th Aug 2014 8:16am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6611 |
Absolutely standard ECU on my 90, 265/75 tyres and pulls a 1.222:1 transfer box beautifully. You do have to swap over certain parts from the Defender box (speedo drive housing), and a Tdi box does not have the high/low switch boss on it in the front cover. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
20th Aug 2014 9:40am |
^^^ My 110 is a lardy beast though....
20th Aug 2014 10:47am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17450 |
Is a Disco 2 TD5 tuned differently to a Defender TD5?
My Disco 2 is running a standard tune and 265/75 BFG Muds and the performance is fine; no issues with the combination of tyres and transfer box ratios. |
20th Aug 2014 4:05pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4786 |
I believe that the disco is 138 bhp as apposed to the defenders 122. Also the disco has smaller diameter tyres so very slightly lower final gearing than a defender would have. 2002 90 Td5 Station Wagon
20th Aug 2014 7:48pm |
Not sure but will check and get back to you. Shutts |____000_ [l_|__\___\,___ l--___--_[O==O] ()_)' '()_)-----()_) 2005 D3 SE 1998 Disco 300tdi - slow play thing 1995 Defender 300tdi - Winching play thing Aprilia RSV 1000 - fast play thing Honda CR250 - noisy play thing Essex Land Rover Club member ------- Andy's Landy's - http://www.andys-landys.blogspot.com Suspension checking workbook - http://www.disco3.co.uk/gallery/albums/use...k_v002.zip |
20th Aug 2014 9:21pm |
BHP may be different, hence my question, but my Disco is on 265/75 Muds which are larger than a standard 90's..
20th Aug 2014 9:28pm |
