Thanks for that think ill leave EGR but have exhaust and re-map fitted. Am hoping to get enough money to have it done at peterbourgh.
One more question sorry.
I believe your box allows me to take the re-map on and off the 110 so I can take it to the dealer.
What happens if the dealer updates the ecu will I lose these updates or will you charge to apply the updates?? I say this because my mate had his ecu updated at last service but he doesnt have a re-map.
27th Jun 2010 2:12pm
bell-auto-services
This is correct, its actually VERY important you return the car to standard tune before any visits, if you have an update done and you have not returned the car to standard we can no longer make new files for the box.
If you loose the tune due to an update and you have returned the car to standard first, we can errase the box and as long as its phisicly possibile a for me a free updated file is made.
If the dealer makes a software change and you have not returned your car to standard first, the box is locked to a non existing car and is rendered usless.
If you are going to Peterborough show and you remind me, i can apply a tune to your car with some other tools for you to have a free trial at the show before you pay.
Ori have a Dealer in Sutton Coldfield if you wish for a sooner trial.
Pete
27th Jun 2010 2:20pm
fekete
mrwoo wrote:
fekete wrote:
bell-auto-services wrote:
Im beleive you are aware probabaly of someone who had a refund after they could not be satisfyed , not that i was not willing to try nor given time unlike you who have given AL plenty of that, it was more that i was only given a very short chance to correct before it was made clear it was never going to be resolved easly with the said person.
Id like to point out this was only about a 4 week buy to full refund window of which the socalled problem was brought to my attention only in the last 4 days of ownership, so i think ive given fantastic customer service compared to your AL dealings.
Pete
Hi Pete, I gather this post was about me unless you've been dishing out more refunds?
I would just like to put the story straight.After receiving your remap...I brought the problem to you the
very next day.I told you it was and wasn't any different to a standard map.I thought I hadn't even
loaded it,it was that bad.You then gave me another remap which undoubtedly had a lot more pull, but
with problems.....ie,flat spots.I then rang you and made you aware of this problem which you told me it's because of the EGR needed blanking to sort the problem. I told you i already had it blanked,to which
you told me I needed a smaller blank. You sold me this map knowing that people were having problems.
And knowing that AL had pulled theirs off the market because of this problem.You then sent me a further
2 maps.....the first one I tried had the flat spots....the second one I tried was better but It was as if the
power had been turned down to overcome the flat spots.Oh,and by the way.....I never asked for a refund....
you offered me 2 options....the first was you told me you could sort this problem out at a further cost and
to drive to your business premises in York......the second was a refund.....I chose the refund as I am a busy man and did not have the time to drive all the way to York.And by the way....my card still hasn't been
credited.....but have I been on the phone to you moaning?? No...I haven't.I thought we weren't going to bring this on to the forum.....I certainly wasn't going to mention it.But I am going to stick up for myself when I'm
getting talked about on here.
Fekete, I dont think you should be sorting your problems with Pete via this forum (Martin?)
I don't think i should either but what are you to do when Pete brings it up...Also what as it got to do with you (Martin?)NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
27th Jun 2010 10:59pm
MK
guys, fit a chip
i have onePuma 110" SW
27th Jun 2010 11:38pm
fekete
MK What chip have you got NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
28th Jun 2010 6:52am
o4dn
And for the rest, this may explane your surging to the odd one of you seem to have and moan about so much lol
EGR closes, air flow over the maf increases, injection increases, power comes with a surging bang.
let of the throttle, egr opens, cuts air flow over the maf, injection decreases power surges off, ohh and if you manage to catch it inbetween the two you sometimes get a mifsire or cough which can in some cases be made worse if the high pressure fuel pump calibration and pilot correction procedure is not completed correctly at the dealers after an update.
Many thanks Pete for that explanation, I think this is exactly what happens with my "stock" (unmodified) Puma...
It's great to finally get a logical and detailed explanation of what happens, rather than the usual denial from the dealer!
This video show that is better to blank the EGR and run with MIL ON!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License
28th Jun 2010 8:06am
MK
I got a Racechip, made in germany. Perhaps it is not as superb as remap, but it does the job making the rig very responsive since 1900ish rpm. You have the chance to adjust it. No smoke, no misfire, no flaty gaps, nothing. My engine has the second version ecu upgrade.Puma 110" SW
MK,
Have you tested max speed?Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License
28th Jun 2010 9:38am
mrwoo
Pete
1964 Series IIA SWB Truck Cab - gone
1981 Series III SWB Hardtop - gone
1982 Series III SWB Hardtop - gone
1997 300Tdi Defender 90 Hardtop - gone
1983 Series III SWB Station Wagon - gone
1979 Series III SWB Station Wagon - gone
2007 90 CSW - gone
2010 USW XS - gone
2010 110 USW - gone
1959 Series II Truck Cab
1984 Series III CSW
2004 TD5 90 CSW
28th Jun 2010 12:00pm
MK
dgardel wrote:
MK,
not really, but still goes over 150 km/h Puma 110" SW
MK,
but without the Racechip is your car limited at 132km/h like in Europe or you car was limiter free from you bought it?Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License
28th Jun 2010 4:11pm
fekete
Thanks for the reply MK i'll look into that as i need something without flat spots NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
28th Jun 2010 4:30pm
Naks
why on earth would you want to drive a Defender at more than 120kmh!?
Hi all,
Have been following the 'remap thread' and the moral of the story is - leave the remap well alone!
Keep to the standard as Defenders were not designed by LR to be 'supercharged in any way'.
As I mentioned in my initial e-mail on the subject spend your money on something else (a nice holiday perhaps!) and be happy with the original. If you want more power buy yourself something else - a Range Rover Supercharged, perhaps?
Just thought I'd enhance the discussion somewhat!
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
