Home > Td5 > TD5 Fuel pump Death
Page 2 of 3 <123>
ttuck3r
Scotland 1999 Defender 90 Td5 HT Caledonian Blue
Thanks but The price i was quoted was more then me buying my own hawkeye..
Post #352202 17th Aug 2014 8:28pm
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Censored that's steep, I know when they were Crow Engineering they were very reasonable, suppose the rates charged by independents will increase relative to the extortionate labour rates the main dealers charge Shocked
Have you had a look here? Don't know how up to date it is though!!
http://www.nanocom-locator.co.uk 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - Gone
2024 110 D250 X-Dynamic HSE
Post #352203 17th Aug 2014 8:32pm
ttuck3r
thanks for the info i will check through that, They used to be really competitive and then when the new owner came in the prices where different every time i went in last year i got quoted 160 for a new windscreen rubber, more expensive then the dealers in perth..
Post #352213 17th Aug 2014 9:20pm
jomara
Madness, you don't retain customers by ripping them off!!
I'm sure one of the mechanics who used to work there has started working for himself. I'll make a call or two tomorrow and find out .
Have you thought about posting on the Scottish Land Rover Owners Club forum see if anyone has a Nanocom or hawkeye?
J 2014 110 2.2TDCi XS Station wagon
Post #352214 17th Aug 2014 9:23pm
ttuck3r
I've got my hands on a diagnostic machine and this is the codes that came up - Who can decipher this, I know the waste gate code here don't apply as the defender doesn't have a sensor there, and the driver demand stuff are the pedals. It's the first 4 and the last one I'm needing explained.
Post #352397 18th Aug 2014 7:31pm
ttuck3r
Im holding fingers its not a dead ECU...
Post #352399 18th Aug 2014 7:33pm
ozzy57
2002 Defender 110 Td5 CSW Alveston Red
IIRC from my Disco days, there were two components that stopped the engine from firing up. One is the cps, and the other was the throttle potentiometer.
Feel free to call me a knob and correct me...........
......... or just call me a knob. It wasn't me!
Post #352879 21st Aug 2014 12:16pm
ttuck3r
What is a CPS?
Post #353016 21st Aug 2014 8:51pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
crank postion sensor.
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #353022 21st Aug 2014 9:09pm
ttuck3r
That has the ability to stop power getting to the fuel lift pump?
Post #353041 21st Aug 2014 9:59pm
Stue5
Italy 2005 Defender 110 Td5 USW Alpine White
Asking someone more resposable! Could it have anything to do with the "fuel cut of switch" somewhere down the line?
 Range Rover p38 4.6 99 lpg(gone Sad )
Post #353063 22nd Aug 2014 7:02am
ttuck3r
Thanks for the reply, I've checked this and it's working.
Post #353065 22nd Aug 2014 7:07am
austinhealey55
2003 Defender 110 Td5 HT Chawton White
Any progress??
I think if this was mine I'd pull the plugs off the ECU and make sure there's no water in there. I've never done it myself but I'd be tempted to remove the ECU from the driver's seat box and remove the top cover to let it dry out, if you think water got in there. It seems a little suspect that this problem happened right around the time the seatbox got wet, especially if you can start the pump by jumping wires otherwise.
This link shows the cover removal:
http://www.discovery2.co.uk/Injector_harness.html
Before things start to get expensive I'd try some basics too -- clean the grounds to the frame and bulkhead, and maybe jump start it to see if it's a low voltage issue.
From what I've read briefly the driver demand codes are the throttle, although it could be coming from either a faulty ECU or the throttle itself.
But the fact it's an on-off issue sounds like a dodgy ECU... found these links which could perhaps help. Let us know how you get on.
http://www.aulro.com/afvb/electronic-diagn...codes.html
http://www.landroveraddict.com/forums/thread.cfm?threadID=30040
Post #353169 22nd Aug 2014 6:57pm
ttuck3r
Thank you Very much for all the info, i will be working through it this evening and climb back into the landy tomorrow to see if anything lets up..
Post #353182 22nd Aug 2014 8:28pm
jimbob7
Speaking to a few of the fitters at work and elsewhere,your really best off with a specific LR diagnostics, their experience shows Snap on to be not as "reliable" as the rest, Testbook, Autologic, even the domestic diagnostics are better than Snap on,Hawkeye,Nanocom, I have the Br*tpart Lynx which was developed with Omitec who wrote LR's Testbook and can't fault it. Also Snap on use generic fault codes,which doesn't always help. A quick Google of Autologic diagnostic in Scotland throws up a few results.
If you need a new fuel pump,these claim to be OEM, VDO pumps,I've no experience of them so cant qualify their claims.But 400 cheaper than LR it has to be worth looking into.
http://www.ebay.co.uk/itm/111185943290?_tr...EBIDX%3AIT Pov.spec,ftw. 2006, 110,TD5.
Post #353262 23rd Aug 2014 10:48am
Page 2 of 3 <123>
