![]() | Home > Maintenance & Modifications > Grille options |
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 ![]() ![]() ![]() |
Flatdog have one made for them by Mantec, I have one fitted to my 110, the quality is top notch!!
![]() Click image to enlarge Cheers John 2014 110 2.2TDCi XS Station wagon 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
Or be a cheapskate like me and sort your own style......
DavidS Member Since: 14 Apr 2014 Location: North East Posts: 55 ![]() ![]() ![]() |
Like both of those
Nowt the matter with that JWL!! I built a 200TDi 110 CSW expedition motor with my brother in law and we cobbled together a low profile winch bumper out of an old SSEB winch mount which weighed as much as the rest of the car!!
![]() 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
Has anyone fitted zunsport grilles? 2 LandRovers, and counting!
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2774 ![]() ![]() |
When I had this quandary, I just decided to swap out the grey for gloss black which I think looks a lot better
They're not hard to paint to change the look of your front end Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Ronin Member Since: 09 Aug 2012 Location: Kent Posts: 213 ![]() ![]() ![]() |
I've gone for a Zunsport grille with two Lazer LEDs built in. Two versions are available, one with RS-4s (with a built in drl) and a slightly cheaper version with ST-4s (without the drls). Zunsport also make grilles for the air and heater intakes, if you fancy a common approach to all three intakes. I suspect (but do not know) that Zunsport make similar grilles without the light apertures.
http://www.lazerlamps.com/models/grille-ki...rille-kit/ Mine is being delivered on Friday; hopefully I'll be able to mount the grille and lamps over the weekend (I've already removed the factory grille and wired up a relayed +ve, -ve and high beam signal wire to the front end, using the LR genuine auxiliary light switch)... ![]() Click image to enlarge I'll post pictures after fitting if you're interested. Joel Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
leonvh Member Since: 31 Dec 2013 Location: Plombičres Posts: 70 ![]() ![]() ![]() |
I would love to see pictures of the Zunsport grille with Lazer lights. Leon |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17711 ![]() ![]() ![]() |
Is that a Stage 1 V8 grille? If not, may I ask where you got it? I really do prefer that look to the cheapo sagging plastic thing fitted as standard! Genuine Stage 1 V8 grilles seem to be as rare as hens' teeth though. ![]() |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20730 ![]() ![]() |
The KBX Signature grille is new for this year and worth a look.
Nakatanenga heritage style grill?
In black, silver or unpainted so you can paint it to match or contrast with your vehicle. Brendan |
@ Blackwolf, I could tell you that it's a Stage 1 but I won't as it is home made. I swopped an old non air-con radiator panel for the air-con front. Bit of cutting and filling to modernise it from an early 90 version with the key hole and starting handle slot to a Td5 style with the oil cooler vent. Whilst I was out with the filler I filled the square holes where the fin grill is fixed. Two metres of round bar, some mesh and a couple of rattle cans and you're there.
@JWL - Excellent job! Looks mint.
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 ![]() |
id like a zunsport myself but simply cant justify the Money on what is simply a mesh grill with a nice metal suround, so ill ne making my own at some point
