Home > Maintenance & Modifications > Grille options |
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 |
Flatdog have one made for them by Mantec, I have one fitted to my 110, the quality is top notch!!
Click image to enlarge Cheers John 2014 110 2.2TDCi XS Station wagon 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
11th Aug 2014 7:56pm |
Or be a cheapskate like me and sort your own style......
Click image to enlarge |
11th Aug 2014 8:48pm |
DavidS Member Since: 14 Apr 2014 Location: North East Posts: 55 |
Like both of those 2 LandRovers, and counting!
11th Aug 2014 8:51pm |
Nowt the matter with that JWL!! I built a 200TDi 110 CSW expedition motor with my brother in law and we cobbled together a low profile winch bumper out of an old SSEB winch mount which weighed as much as the rest of the car!! 2014 110 2.2TDCi XS Station wagon
11th Aug 2014 8:54pm |
Has anyone fitted zunsport grilles? 2 LandRovers, and counting!
13th Aug 2014 3:36pm |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2762 |
When I had this quandary, I just decided to swap out the grey for gloss black which I think looks a lot better
They're not hard to paint to change the look of your front end Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
13th Aug 2014 4:14pm |
Ronin Member Since: 09 Aug 2012 Location: Kent Posts: 213 |
I've gone for a Zunsport grille with two Lazer LEDs built in. Two versions are available, one with RS-4s (with a built in drl) and a slightly cheaper version with ST-4s (without the drls). Zunsport also make grilles for the air and heater intakes, if you fancy a common approach to all three intakes. I suspect (but do not know) that Zunsport make similar grilles without the light apertures.
http://www.lazerlamps.com/models/grille-ki...rille-kit/ Mine is being delivered on Friday; hopefully I'll be able to mount the grille and lamps over the weekend (I've already removed the factory grille and wired up a relayed +ve, -ve and high beam signal wire to the front end, using the LR genuine auxiliary light switch)... Click image to enlarge I'll post pictures after fitting if you're interested. Joel Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
13th Aug 2014 4:54pm |
leonvh Member Since: 31 Dec 2013 Location: Plombičres Posts: 69 |
I would love to see pictures of the Zunsport grille with Lazer lights. Leon |
5th Sep 2014 11:41am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17491 |
Is that a Stage 1 V8 grille? If not, may I ask where you got it? I really do prefer that look to the cheapo sagging plastic thing fitted as standard! Genuine Stage 1 V8 grilles seem to be as rare as hens' teeth though. |
5th Sep 2014 11:52am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20512 |
The KBX Signature grille is new for this year and worth a look.
5th Sep 2014 12:26pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8582 |
Nakatanenga heritage style grill?
In black, silver or unpainted so you can paint it to match or contrast with your vehicle. Brendan |
5th Sep 2014 12:54pm |
@ Blackwolf, I could tell you that it's a Stage 1 but I won't as it is home made. I swopped an old non air-con radiator panel for the air-con front. Bit of cutting and filling to modernise it from an early 90 version with the key hole and starting handle slot to a Td5 style with the oil cooler vent. Whilst I was out with the filler I filled the square holes where the fin grill is fixed. Two metres of round bar, some mesh and a couple of rattle cans and you're there.
5th Sep 2014 1:11pm |
@JWL - Excellent job! Looks mint.
5th Sep 2014 1:39pm |
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 |
id like a zunsport myself but simply cant justify the Money on what is simply a mesh grill with a nice metal suround, so ill ne making my own at some point
5th Sep 2014 1:42pm |
