Home > Maintenance & Modifications > Grille options
DavidS
United Kingdom 2011 Defender 110 Puma 2.4 USW Stornoway Grey
Grille options
Hi, I want to change the look of the front of my Defender.I have aircon and on my list of changes is a winch bumper + winch, and DRL's.
I like the modern look but what alternatives are there to Kbx, Rdx Svx etc, and do they all fit with winch and aircon? 2 LandRovers, and counting!
Post #351084 11th Aug 2014 7:48pm
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Flatdog have one made for them by Mantec, I have one fitted to my 110, the quality is top notch!!
John 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - Gone
2024 110 D250 X-Dynamic HSE
Post #351086 11th Aug 2014 7:56pm
JWL
Or be a cheapskate like me and sort your own style......
Post #351114 11th Aug 2014 8:48pm
DavidS
Like both of those Very Happy 2 LandRovers, and counting!
Post #351115 11th Aug 2014 8:51pm
jomara
Nowt the matter with that JWL!! I built a 200TDi 110 CSW expedition motor with my brother in law and we cobbled together a low profile winch bumper out of an old SSEB winch mount which weighed as much as the rest of the car!! Shocked 2014 110 2.2TDCi XS Station wagon
Post #351118 11th Aug 2014 8:54pm
DavidS
Has anyone fitted zunsport grilles? 2 LandRovers, and counting!
Post #351415 13th Aug 2014 3:36pm
Cheshire110
When I had this quandary, I just decided to swap out the grey for gloss black which I think looks a lot better
They're not hard to paint to change the look of your front end Cheers, David
Post #351419 13th Aug 2014 4:14pm
Ronin
United Kingdom 2014 Defender 90 Puma 2.2 ST Keswick Green
I've gone for a Zunsport grille with two Lazer LEDs built in. Two versions are available, one with RS-4s (with a built in drl) and a slightly cheaper version with ST-4s (without the drls). Zunsport also make grilles for the air and heater intakes, if you fancy a common approach to all three intakes. I suspect (but do not know) that Zunsport make similar grilles without the light apertures.
http://www.lazerlamps.com/models/grille-ki...rille-kit/
Mine is being delivered on Friday; hopefully I'll be able to mount the grille and lamps over the weekend (I've already removed the factory grille and wired up a relayed +ve, -ve and high beam signal wire to the front end, using the LR genuine auxiliary light switch)...
I'll post pictures after fitting if you're interested.
Joel
Post #351427 13th Aug 2014 4:54pm
leonvh
Belgium 2013 Defender 110 Puma 2.2 SW Barolo Black
I would love to see pictures of the Zunsport grille with Lazer lights.
Leon
Post #355867 5th Sep 2014 11:41am
Is that a Stage 1 V8 grille? If not, may I ask where you got it?
I really do prefer that look to the cheapo sagging plastic thing fitted as standard! Genuine Stage 1 V8 grilles seem to be as rare as hens' teeth though. Big Cry
Post #355874 5th Sep 2014 11:52am
The KBX Signature grille is new for this year and worth a look.
Post #355885 5th Sep 2014 12:26pm
leeds
Nakatanenga heritage style grill?
In black, silver or unpainted so you can paint it to match or contrast with your vehicle.
Brendan
Post #355887 5th Sep 2014 12:54pm
JWL
@ Blackwolf, I could tell you that it's a Stage 1 but I won't as it is home made. I swopped an old non air-con radiator panel for the air-con front. Bit of cutting and filling to modernise it from an early 90 version with the key hole and starting handle slot to a Td5 style with the oil cooler vent. Whilst I was out with the filler I filled the square holes where the fin grill is fixed. Two metres of round bar, some mesh and a couple of rattle cans and you're there.
Post #355888 5th Sep 2014 1:11pm
@JWL - Excellent job! Looks mint. Thumbs Up
Post #355890 5th Sep 2014 1:39pm
theorangebandit
id like a zunsport myself but simply cant justify the Money on what is simply a mesh grill with a nice metal suround, so ill ne making my own at some point
Post #355893 5th Sep 2014 1:42pm
