Home > Technical > I think it's broken
stevie d
United Kingdom 2003 Defender 90 Td5 SW Alpine White
I think it's broken
Doing about 60mph on slip road, coming off motorway.
Thought I had a flat tyre - truck jumping about and pulling to left.
Pulled over and had a look around - nothing obvious.
Got going again and ok until about 30mph when shaking started again,
Managed to get home and further look around - checked prop shafts and looked for oil leaks, still nothing
Any ideas guys.
Steve Defender 90 TD5 Station Wagon
Discovery 3 HSE
BMW 330i Coupe
Post #35068 25th Jun 2010 10:43pm
KarlB
Australia 2010 Defender 90 Puma 2.4 XS CSW Rimini Red
The first thing I would do is check (in the following order):
1. Are the wheel nuts tight.
2. Is there a damaged tie rod or more particularly a damaged or worn out tie rod end.
3. Brakes.
My best guess would be No 2. A failed tie rod end can certainly lead to wheel wobble and to pulling to one side.
KarlB
Post #35073 26th Jun 2010 12:41am
110SEB
This forum is brilliant. Proper helpful considered advice shared willingly from all around the globe.
I hope you get the problem sorted quickly. Not being a mech-head particularly my first instinct was a steering rod/wheel issue.
Post #35074 26th Jun 2010 5:33am
stevie d
Hi,
Checked wheel nuts at road side - all ok
Replaced brake pads a month or so ago, so I don't think this is the problem, but will need to get wheels off to be sure.
How would I check tie rod ends? Is visual enough?
Cheers,
Discovery 3 HSE
BMW 330i Coupe
Post #35078 26th Jun 2010 7:23am
mse
stevie d wrote:
Hi,
Cheers,
Steve
Visual - but take a crowbar and prize the joints as it could look ok Mike
Post #35080 26th Jun 2010 7:41am
KarlB
You can often see tears in the rubber boot of the Censored tie rod end and often get obvious movement if you just give it a push with your hand. Best thing to do is jack each wheel up in turn (start with the left as that is the most likely side). Make sure that the on the ground wheel is chocked front and back (couple of old house bricks or lumps of wood would be fine) then see if the off the ground wheel has any left to right movement by pushing it front then back. There should be little movement as it is tied (by the tie rods) to the chocked wheel on the ground.This can be more effective if you get a mate to do the pushing on the wheel while you look at the tie rod ends.
Post #35096 26th Jun 2010 12:04pm
KarlB
I should have added, if it is not a tie rod end problem then I suggest you get the vehicle to a mechanic. Other possible issues could be wheel bearings, suspension, steering box, swivel pins, etc. I still suspect a tie rod end issue though. Do keep us informed how you get on Steve.
KarlB
Post #35098 26th Jun 2010 12:14pm
Grockle
just a thought you didn't have the dif lock in did you 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #35103 26th Jun 2010 1:50pm
Sounds like classic panhard rod bushes/bolts or swivel pre-load.
Post #35109 26th Jun 2010 4:53pm
roel
My bet is the left front wheel bearing, as i came sudden as I understand. A tie rod I would expect to be a graduall wear.
Like Garl said lift the wheel up off the grouns and put one hand at each side i.e front and rear and pull with one hand and push with the other and otherway around. If you feel play you just have to check if it is the wheel bearing or tie rod.
Did your brake pedal get more travel braking? If so it is wheelbearing. Roel
2003 90 Td5 (2009-now)
Post #35123 26th Jun 2010 7:23pm
eutek
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
This is exactly what happened to me while driving the Mrs' Mercedes. It turned out to be the bearing.
Post #35126 26th Jun 2010 7:35pm
the gamekeeper
England 2007 Defender 110 Puma 2.4 DCPU Tonga Green
Check the steering box tie bar. I had it crack on one of my landies once and at 30mph it rattled throught the steering.
Tony
Post #35127 26th Jun 2010 7:39pm
stevie d
Hi Guys,
Turns out to be the LHS wheel bearing, unfortunately no early signs just failure.
Once I got the wheel off the ground the wheel was loose, about 5-10mm of play all round.
I had already called the AA and he confirmed Bearing.
Just need to fix it now.
Are there any threads on this site for replacing bearings, I would like to have ago myself.
Discovery 3 HSE
BMW 330i Coupe
Post #35131 26th Jun 2010 8:38pm
stevie d
Roel,
I just noticed you said the brake pedal may have more play with a wheel bearing problem.
Why is this?
I have noticed recently that the brake pedal has been either firm or loose on any given day.
Discovery 3 HSE
BMW 330i Coupe
Post #35132 26th Jun 2010 8:53pm
Laurie
Steve
If you don't understand why the brake pedal gets longer when you have a knackered wheel bearing, I seriously doubt your ability to change the bearing.
Get it done by a professional, it's a critical safety issue.
Post #35136 26th Jun 2010 9:28pm
