![]() | Home > Technical > I think it's broken |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
This is an interesting read:
http://forums.lr4x4.com/index.php?showtopic=8009 |
stevie d Member Since: 09 Nov 2009 Location: Bishops Stortford Posts: 342 ![]() ![]() ![]() |
Thanks Roel, I now understand.
Wheel bearing changed this morning with a lot of help from Landyandy and his spare bearings. I will now work on the other 3 asap. It turns out the drive flange was fairly corroded as is the offside front and the bearing dry as dry, so offside front in particular will need doing as a matter of urgency. I had a quick look at one of the rear bearings. A fair glug of diff oil came out - so bearing running in diff oil? Is that a problem? Steve Defender 90 TD5 Station Wagon Discovery 3 HSE BMW 330i Coupe Last edited by stevie d on 27th Jun 2010 6:42pm. Edited 1 time in total |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5822 ![]() ![]() |
Hi Steve,
Thats is because the seal between the axle and stub axle has been damaged or removed. This is not a prob, and some people do it so that the bearing are lubed by the diff oil, and will probably last longer this way, also stops the splines from wearing. Andy |
Andy,
Thanks for your help and time this morning, very much appreciated. ![]() I guess I can leave the rear bearings for now as they seem ok? Steve ![]() Discovery 3 HSE BMW 330i Coupe |
Well worth a check as it will only cost you the price of a new nut. The other side may not be the same.
But the O/S/F is urgent. Andy |
Personally I prefer grease for bearings, but as long as there is grease or oil it will be OK. For the splines? I don't have them on my Camel or 90 at the wheel side on the rear axle.
With my Camel I had to change the bearings in the first year I had the Camel. The other six years and almost 100000 Miles I didn't have problems. Ok I did maintenance about every year, I took the outer bearing out and stuffed the opening completely full with new grease, I also stuffed the bearing full with grease and I assembled everything again. Adjusted the bearing play. I took me a few hours every year but never had problems again. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
