Home > Maintenance & Modifications > Swivel Pin Corrosion
Merlin
Just filled up the swivel pins and noticed that the near side one has two groves on it. Is this cause for concern? Picture below:
Could have been partly caused by an enthusiastic outing on Salisbury Plain, hence the weed.
Merlin
Post #350568 9th Aug 2014 4:23pm
Retroanaconda
The balls do corrode, nothing much you can do about it other than using the car regularly and keeping it clean underneath. Even then eventually they will give up.
When they do the corrosion will eventually get to the point where it damages the seal and the oil/grease will leak out. When this happens replace the balls and repeat the process Smile
Post #350570 9th Aug 2014 4:27pm
munch90
are they grooves or just shinny bit where to seal has sit when steering straight ,
is there any play in the swivels top and bottom ?
Post #350571 9th Aug 2014 4:27pm
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Anybody tried spraying them with ACF50 regularly?? 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - Gone
2024 110 D250 X-Dynamic HSE
Post #350581 9th Aug 2014 4:48pm
munch90
I spray them with waxoyl , still like new
Post #350582 9th Aug 2014 4:49pm
jomara
Good to know, prevention is better............and all that Thumbs Up 2014 110 2.2TDCi XS Station wagon
Post #350583 9th Aug 2014 4:50pm
