Home > Puma (Tdci) > Alpine radio problems |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20121 |
So I've just read, you can't use the front port for iPod only for a USB flash drive.
You can use the rear socket though but you will need the iPod cable from Alpine. Exactly the same as my Kenwood works, no doubt the cable is pricey. The Kenwood cable is nearly £30 |
5th Aug 2014 5:52pm |
Trundlebus Member Since: 15 Jul 2014 Location: Herts Posts: 95 |
Now that's peculiar, in the handbook it clearly says to connect an MP3 player or similar device!
I would call landrover but I think they wouldn't have a clue! |
5th Aug 2014 6:06pm |
An MP3 player can be different in file format, also using a 3.5mm audio jack in some cases.
5th Aug 2014 6:13pm |
adamatdraycott Member Since: 11 Nov 2013 Location: Midlands Posts: 299 |
Why not bluetooth your tunes to the head unit and just charge via the USB?
Bluetooth works brilliantly on mine, had my phone and ipad hooked up numerous times and everything works fine. |
5th Aug 2014 7:26pm |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1577 |
My iphone works fine on my alpine head. I plug it in the front everyday. It won't however charge my ipad.
I had an issue a while back and found my lead was at fault. |
5th Aug 2014 7:32pm |
Well, I have the alpine cde-130r, which according to the alpine manual on their website, it has no Bluetooth and only allows USB sticks. So I guess it all depends what LR put in as to what works. It bears no relation to the defender handbook as far as I can tell, it's ok as I can use the jack plug to connect the iphone.
5th Aug 2014 7:45pm |
Sorry I have the upgraded Bluetooth one. Don't take any notice of my comments. Sorry
5th Aug 2014 8:18pm |
No worry ro key, any input is a help and I appreciate you taking the time to give suggestions.
Thanks |
5th Aug 2014 9:50pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5571 |
When you press the source button what options are you given?
Andy |
5th Aug 2014 11:05pm |
Hi Andy,
Only three options, rds, regional and pi seek, so now I which radio it is and I have the correct instructions. At least that mystery is solved! |
6th Aug 2014 9:07am |
Does it not list USB, tuner, iPod ect.?
6th Aug 2014 9:05pm |
in the defender owners manual YES, in the Alpine user manual it states that the usb can only be used for a USB storage device. Unfortunately that seems to be how it works. So I think the LR manual is describing a more upmarket version.
6th Aug 2014 9:25pm |
Check the back for the USB there..
6th Aug 2014 10:03pm |
Will do
thanks to all for your help |
7th Aug 2014 5:01pm |
