Home > Puma (Tdci) > Alpine radio problems
Trundlebus
So I have just taken delivery of my 6 month old 130 and have been trying to use the radio. It works but
I plug in a USB from my iphone or ipad and it says "USB err 1" the handbook makes no mention of error codes so don't know what it means and 2 when I go to audio set up I have very limited options, I know I am doing some thing wrong but what?
Any clues?
Thanks
Post #349682 5th Aug 2014 4:56pm
So I've just read, you can't use the front port for iPod only for a USB flash drive.
You can use the rear socket though but you will need the iPod cable from Alpine.
Exactly the same as my Kenwood works, no doubt the cable is pricey.
The Kenwood cable is nearly £30
Post #349688 5th Aug 2014 5:52pm
Trundlebus
Now that's peculiar, in the handbook it clearly says to connect an MP3 player or similar device!
I would call landrover but I think they wouldn't have a clue!
Post #349690 5th Aug 2014 6:06pm
An MP3 player can be different in file format, also using a 3.5mm audio jack in some cases.
Post #349694 5th Aug 2014 6:13pm
adamatdraycott
United Kingdom 2014 Defender 90 Puma 2.2 SW Corris Grey
Why not bluetooth your tunes to the head unit and just charge via the USB?
Bluetooth works brilliantly on mine, had my phone and ipad hooked up numerous times and everything works fine.
Post #349708 5th Aug 2014 7:26pm
RobKeay
My iphone works fine on my alpine head. I plug it in the front everyday. It won't however charge my ipad.
I had an issue a while back and found my lead was at fault.
Post #349709 5th Aug 2014 7:32pm
Trundlebus
Well, I have the alpine cde-130r, which according to the alpine manual on their website, it has no Bluetooth and only allows USB sticks. So I guess it all depends what LR put in as to what works. It bears no relation to the defender handbook as far as I can tell, it's ok as I can use the jack plug to connect the iphone.
Post #349711 5th Aug 2014 7:45pm
RobKeay
Sorry I have the upgraded Bluetooth one. Don't take any notice of my comments. Sorry
Post #349722 5th Aug 2014 8:18pm
Trundlebus
No worry ro key, any input is a help and I appreciate you taking the time to give suggestions.
Thanks
Post #349768 5th Aug 2014 9:50pm
landy andy
When you press the source button what options are you given?
Andy
Post #349810 5th Aug 2014 11:05pm
Trundlebus
Hi Andy,
Only three options, rds, regional and pi seek, so now I which radio it is and I have the correct instructions. At least that mystery is solved!
Post #349871 6th Aug 2014 9:07am
landy andy
Does it not list USB, tuner, iPod ect.?
Post #350006 6th Aug 2014 9:05pm
Trundlebus
in the defender owners manual YES, in the Alpine user manual it states that the usb can only be used for a USB storage device. Unfortunately that seems to be how it works. So I think the LR manual is describing a more upmarket version.
Post #350012 6th Aug 2014 9:25pm
Check the back for the USB there..
Post #350026 6th Aug 2014 10:03pm
Trundlebus
Will do
thanks to all for your help
Post #350163 7th Aug 2014 5:01pm
