Home > Puma (Tdci) > puma gearchange clunking
Page 2 of 3 <123>
landy andy
Yes mate Thumbs Up Why the question?
Post #349201 3rd Aug 2014 11:38am
munch90
only reason I asked is while ago I looked at fitting one , but thought maybe it would push air under the axle and making axle run hotter
bit of a long shot I know ,but only a thought
Post #349205 3rd Aug 2014 12:02pm
landy andy
My 10 reg is at 45 thou miles, and I've only had it 9months, and steering guard fitted about 6 months.
I now can't stop driving it, it's fun king great, best drive ever, zero play great drive, fun, fun.
Andy
Post #349323 3rd Aug 2014 8:36pm
LR90XS2011
My 90 is a 2011 and the build sheet says 2 pin diff, I think only 110 and 130 had 4 pin in 2011 DEFENDER 90 TDCI XS,
Post #349384 4th Aug 2014 5:25am
landy andy
Yes that's correct, only 110's got given the four pin mid 10 reg. 90's have two pin.
Andy
Post #349391 4th Aug 2014 5:48am
Regard
South Africa 2011 Defender 110 Puma 2.4 X-Tech LE Orkney Grey
I have a 2011 110 X-Tech and the build sheet still says 2 pin front diff.
See here:
Post #349513 4th Aug 2014 7:39pm
landy andy
Oh. Not good, what's the drive like? Any clonking?
Does it show the manufacture date?
Andy
Post #349514 4th Aug 2014 7:48pm
Regard
Yep, pretty clunky.
Tried to find build date but can't find it on Topix?
Post #349515 4th Aug 2014 7:51pm
landy andy
Just looking at your avatar, so thought may have been built early before shipping out to you.
Would recommend a visual check through the diff filler hole, saved me some trouble.
Andy
Post #349516 4th Aug 2014 7:55pm
Regard
Aaahhhhh....how could I forget....
My front diff was replaced just 3 months ago due to accident damage.
I hope and believe they would have replaced it with a 4 pin???
Post #349525 4th Aug 2014 8:15pm
newhue
Australia
It looks like a visual check will be the only way of knowing for sure. Doesn't look like LR's record keeping has improved over the years. If you talk to the series boys, what the records say, and what was built or exported can be a little different. My Defender and travels
Post #349528 4th Aug 2014 8:22pm
Bearing in mind that your build spec also says you have a "2 pin" rear diff when you have a P38 diff, I wonder if this is confusion caused by nomenclature. Remember that the two options are firstly a diff with a single cross-pin which carries two differential gears (the weak one), and secondly a diff with two cross-pins carrying four differential gears (the strong one). Quite where and how the expressions "two pin" and "four pin" which are so widely bandied about come from is a mystery (it may be that the diff gears are being incorrectly referred to as pinions, hence 2 or 4, but they are not).
If on your build sheet LR is being technically accurate they may be saying both your diffs have two cross-pins and hence four differential gears, which is what we would expect.
Post #349537 4th Aug 2014 9:13pm
munch90
when we were doing lots of race boxes ( not land rover) it was called a one pin ( or standard one ) or the uprated one was called the two pin
Post #349545 4th Aug 2014 9:30pm
landy andy
Must admit I have always questioned the two/four pin name, as it makes no sense.
I was really pleased to see my front diff was shot, if it had been ok, I would have been questioning the boxes, and I don't want to go there Rolling Eyes Diff's are easily changed, and easily upgraded.
Andy
Post #349546 4th Aug 2014 9:33pm
munch90
but then a 2 pin is really a 3 pin , one long pin and two short ones Rolling with laughter
Post #349550 4th Aug 2014 9:37pm
Page 2 of 3 <123>
