Home > Puma (Tdci) > TDCI Water Useage? |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2646 |
Most likely it's the coolant cap, it only leaks under pressure.
Mine was also leaking coolant, and I replaced it on advice from the chaps here. There was no more topping up after that Replace it and monitor, it's cheap and you can replace it every year -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
28th Jul 2014 7:09pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3646 |
Mines 2011 used no coolant in the 3 years I've had it, hope its not serious DEFENDER 90 TDCI XS,
28th Jul 2014 7:39pm |
pjw4233 Member Since: 30 Nov 2009 Location: Lake District & Cheshire Posts: 273 |
Probably coolant cap, I was losing coolant via the coolant cap when engine was being worked hard, with air conditioning running during the recent hot weather. I've had no further problems since replacing cap despite the hot weather . A £6 fix
29th Jul 2014 10:48pm |
Kevzeboy Member Since: 19 Jul 2014 Location: Cumbria Posts: 87 |
Thanks Chaps! Coolant Cap ordered from Barry 4x4. Let's hope it's the cheap fix!
Terraferma diff guards winging there way too! Kevin |
30th Jul 2014 5:56am |
110 John Member Since: 11 Jan 2014 Location: Northumberland Posts: 158 |
I havent had to top mine up at all 32000
30th Jul 2014 9:59am |
