Home > Puma (Tdci) > TDCI Water Useage?
Kevzeboy
United Kingdom 2011 Defender 110 Puma 2.4 USW Indus Silver
TDCI Water Useage?
I have a 2011 2.4 TDCI with 44500 miles on the clock. When I bought her in January she had 41500 on. Long story short: in the 3000 miles I have covered in her she has used a an about a pint of coolant with no sign of any leaks.
Is this the sign of a head gasket going or is it normal? No contamination in coolant etc.
I don't know if it is relent, but when it was colder there was a little puff of blue smoke on cold starting. She has never used any oil since getting her though.
Under warranty till the end of Aug!
Any thoughts or experiences on the matter welcome.
Kevin.
Post #348072 28th Jul 2014 6:27pm
Naks
Most likely it's the coolant cap, it only leaks under pressure.
Mine was also leaking coolant, and I replaced it on advice from the chaps here. There was no more topping up after that Thumbs Up
Replace it and monitor, it's cheap and you can replace it every year --
Post #348092 28th Jul 2014 8:09pm
LR90XS2011
Mines 2011 used no coolant in the 3 years I've had it, hope its not serious DEFENDER 90 TDCI XS,
Post #348105 28th Jul 2014 8:39pm
pjw4233
United Kingdom 2011 Defender 90 Puma 2.4 HT Stornoway Grey
Probably coolant cap, I was losing coolant via the coolant cap when engine was being worked hard, with air conditioning running during the recent hot weather. I've had no further problems since replacing cap despite the hot weather . A �6 fix Smile
Post #348329 29th Jul 2014 11:48pm
Kevzeboy
Thanks Chaps! Coolant Cap ordered from Barry 4x4. Let's hope it's the cheap fix!
Terraferma diff guards winging there way too!
Kevin
Post #348338 30th Jul 2014 6:56am
110 John
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Orkney Grey
I havent had to top mine up at all 32000
Post #348357 30th Jul 2014 10:59am
