Home > Puma (Tdci) > Taca-taca-taca noise
Eduardo
Hi there!
I have an annoying noise (taca-taca-taca) when the Defender is stopped in neutral. As soon as I press the clutch the noise dissapeared. Also the noise are not present in any gear (except neutral) or when the Defender is moving in neutral.
Looks like coming from the bell housing or near this point.
Any thoughts about the origin?
Thanks! Eduardo
Post #347973 28th Jul 2014 4:31am
bear100
I was going to post the same Shocked for some reason mine has started to do the same Evil or Very Mad I have also noticed mine has a vibration noise when just pulling off it only lasts about 1-2 seconds 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #347980 28th Jul 2014 7:02am
munch90
sounds like clutch springs getting loose
Post #347992 28th Jul 2014 8:25am
Re: Taca-taca-taca noise
Puma clutch death rattle.
Switch the engine off with the box in neautral and the clutch in (ie foot off pedal). Repeat with clutch out (foot on pedal). Compare the sounds. If the former results in a sharp rattle and the latter does not, get a new driven plate fitted sooner rather than later.
It sounds to me like a classic rattle caused by the driven plate springs taking on a permanent set and becomeing loose. If so and if left too long they will fall out and (a) the vehicle will be undrivable and (b) the repair will be more expensive.
Life expectancy of the latest (hence best) driven plates seems typically to be 50k to 80k miles, dependent upon use.
Post #347998 28th Jul 2014 8:48am
bear100
Shocked mines only done 30k Big Cry will try the test later
Thumbs Up 2016 Range Rover Autobiography 4.4 TDV8
Post #348008 28th Jul 2014 10:45am
Eduardo
Ouch,
You confirm my fears Crying or Very sad Crying or Very sad
Well. I have 140.000 km in the clock with this clutch...
Was changed under guarantee at thr 40.000 km. Eduardo
Post #348040 28th Jul 2014 12:52pm
Eduardo
Quick question:
Its worth to use the LR original spare or AP drive is OK? Eduardo
Post #348056 28th Jul 2014 3:34pm
Mongolia
France
Hi eduardo,
My first plate was changed under guarantee at 60.000 kmon the clock and the last done 135.000 km : one spring dropped on the clutch.
The new one is a genuine, why not? Now, they say they have no return
Post #348060 28th Jul 2014 4:12pm
There should be no difference between AP and gen LR, both are from same source. I was surprised to find that my brand new AP driven plate rattled when I shook it straight out of the box, but it is silent now it's fitted.
I will probably change it every 50k miles (2 years for me) ad a matter of routine now.
Post #348068 28th Jul 2014 4:56pm
Eduardo
Thanks Thumbs Up Eduardo
Post #348082 28th Jul 2014 6:21pm
Raddy
Guernsey 2007 Defender 90 Puma 2.4 CSW Rimini Red
I've noticed mine has started doing this recently.. oh dear! Rolling Eyes
Post #348086 28th Jul 2014 6:38pm
Naks
Yep, with the Puma, best you start and switch off the engine with the clutch in. Thumbs Up --
Post #348093 28th Jul 2014 7:10pm
Don't you mean out (ie pedal pressed)?
Post #348107 28th Jul 2014 7:43pm
bear100
How much would this repair cost? 2016 Range Rover Autobiography 4.4 TDV8
Post #348109 28th Jul 2014 7:46pm
Eduardo
Not so cheap according to LRDirect
Depend of the piece manufacturer:
Between 44 (Bearmach)-65 (LR genuine) GBP for the clutch Slave bearing (i'm not sure if is neccesary to change it)
Between 88 (Britpart)-213 (LR genuine) GBP for the clutch repair kit
All that plus the labour cost.
Already ask for a quotation from one of our forum sponsors.
Here in Chile the cost is over 550 GBP plus labour for an OEM source Shocked Eduardo
Post #348121 28th Jul 2014 8:28pm
