Home > Puma (Tdci) > Taca-taca-taca noise
Page 2 of 2 <12
munch90
replace bearing , I would not risk leaving it
bearing and cylinder are one unit in the bell housing , so you can't change it after
Post #348122 28th Jul 2014 8:33pm
I had one fitted by a main dealer 3 years ago (driven plate, cover, slave cylinder, and restrictor replaced) and it cost about UK£1k Shocked
This time I replace it myself, parts were about £250 all in, it took a day to fit but this included quite a lot of additional work (replacement t-box, handbrake overhaul, oil changes, and full clutch and gear lever linkage overhaul).
Post #348147 28th Jul 2014 10:37pm
BigWheels
Mine dose it too, but not all the time. When still, put into 2nd gear, release clutch to biting point, press clutch, go into neutral, release clutch. Usually back to normal.
Stopping in 1st gear, or switching from low to high box is what normally cause the noise for me. Stopping in 2nd gear results in no tac-tacing. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #348998 2nd Aug 2014 1:20pm
Eduardo
Well,
Spares already bougth abd now waiting the delivery fro UK (Thanks Dan)
Probably the change will be in 2 weeks more when the defender will be available
Cheers Eduardo
Post #349480 4th Aug 2014 4:40pm
Eduardo
Sorry to resurrect this old post
My Indi is working in the Defender puting the new clutch.
Unfortunately the flywheel is warped and cannot be recovered Crying or Very sad
So should be changed Evil or Very Mad
I feel more poor than 10 minutes ago Crying or Very sad Eduardo
Post #361286 30th Sep 2014 6:30pm
shaggydog
Sorry to hear this.
I have very recently had the same issue with mine so can completely understand the sinking feeling when they say its not just the clutch, its the flywheel too.
Hope it gets sorted for you.
Post #361312 30th Sep 2014 7:57pm
HardCharger
So if this has to be done, asides from the clutch plate and the bearing, is there anything else we should be looking to replace while the transmission is opened up anyways?
Post #392636 26th Jan 2015 6:07am
Yes, while the gearbox is out, seperate the gearbox and transfer box and inspect the gearbox output extension shaft splines.
There have been many cases of this splined joint failing completely due to fretting resulting from no lubrication on assembly, and failure results in total loss of drive. It is definitely worth inspection and even if it looks OK greasing it thoroughly with a molybdenum disulphide grease whenever you get the chance.
Post #392662 26th Jan 2015 10:00am
HardCharger
Thanks blackwolf. Will have them do that when the time comes.
Post #393198 28th Jan 2015 3:38am
Page 2 of 2 <12
