Home > Maintenance & Modifications > Scanguage location
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
Scanguage location
I have mine sat in the top of the centre dash in that little tray area but I don't like it there. Any ideas on a better location? I don't like it in front of the instrument binnacle either!
Post #347722 26th Jul 2014 4:54pm
Down near the gear selectors area? Might be a bit big though.
Post #347723 26th Jul 2014 4:57pm
ZeDefender
It's going to be dangerous anywhere you can't see it easily whilst driving. Mine's velcroed on the top of the steering column against the instruments. It's actually not that distracting and only really blocks the headlamp dim/dip light. Also, there's a nice little hole already in the column fascia for the wire to come out of so it's nice and tidy Thumbs Up Tell someone you love them today because life is short.
Post #347745 26th Jul 2014 6:45pm
K9F
Mine is neatly mounted on the rear view mirror. Perfect location out of the way but at eye level for easy reference. Get the Blendmount Kit, prise the mirror glass out of the housing get a small nut and bolt and secure the Blendmount bracket to the housing. Refit the glass and remount the rear view mirror. Job jobbed but it's up to you. Been secured up there for nearly four years now.
http://www.defender2.net/forum/topic3719.html?highlight=scangauge If you go through life with your head in the sand....all people will see is an ar5e!!
Post #347749 26th Jul 2014 6:51pm
ZeDefender
Can't see the pictures on that thread Whistle
p.s. so you hid your OBD in the rear view mirror? Cunning Laughing Tell someone you love them today because life is short.
Post #347754 26th Jul 2014 7:34pm
K9F
Pictures got binned ages ago.
But here's a little You Tube clip that will undoubtedly give you the right idea. Thumbs Up
OBD is locked and left at home. As long as I don't travel further than the 200m lead length I'm fine. Thud
Different twist........ Rolling with laughter Bow down Rolling with laughter
Instead of a picture of a Land Rover with a large hole in it.....
Here is a big hole with a Land Rover in it.
Post #347773 26th Jul 2014 9:36pm
LR90XS2011
Mine is held with velcro just below and to the right of the steering column on the little shelf that runs across, I find it fine there for a quick glance when I want to see whats going on DEFENDER 90 TDCI XS,
Post #347789 27th Jul 2014 5:20am
