![]() | Home > Maintenance & Modifications > Scanguage location |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20593 ![]() ![]() |
Down near the gear selectors area? Might be a bit big though.
It's going to be dangerous anywhere you can't see it easily whilst driving. Mine's velcroed on the top of the steering column against the instruments. It's actually not that distracting and only really blocks the headlamp dim/dip light. Also, there's a nice little hole already in the column fascia for the wire to come out of so it's nice and tidy
![]() But shout it at them in German because life is also terrifying and confusing... |
Mine is neatly mounted on the rear view mirror. Perfect location out of the way but at eye level for easy reference. Get the Blendmount Kit, prise the mirror glass out of the housing get a small nut and bolt and secure the Blendmount bracket to the housing. Refit the glass and remount the rear view mirror. Job jobbed but it's up to you. Been secured up there for nearly four years now.
http://www.defender2.net/forum/topic3719.html?highlight=scangauge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Can't see the pictures on that thread
![]() p.s. so you hid your OBD in the rear view mirror? Cunning ![]() But shout it at them in German because life is also terrifying and confusing... |
Pictures got binned ages ago.
But here's a little You Tube clip that will undoubtedly give you the right idea. ![]() OBD is locked and left at home. As long as I don't travel further than the 200m lead length I'm fine. ![]() Different twist........ ![]() ![]() ![]() Instead of a picture of a Land Rover with a large hole in it..... Here is a big hole with a Land Rover in it. ![]() Treat every day as if it is your last....one day you will be right!! |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3651 ![]() ![]() ![]() |
Mine is held with velcro just below and to the right of the steering column on the little shelf that runs across, I find it fine there for a quick glance when I want to see whats going on DEFENDER 90 TDCI XS,
