![]() | Home > Maintenance & Modifications > hand brake tricks |
there was a recall for oil contaminated shoes that was caused by the seal
search p022 |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6324 ![]() ![]() ![]() |
Recall was done thanks mate.
Shame your 'recollection' isn't as good about the subject matter. ![]() Caterham, I've already seen the inside of your drum and the marks from the last time you took it apart 14 months ago. This is not fresh news. Why not continue one of the last two threads you started on exactly the same subject within a month of each other? ![]() http://www.defender2.net/forum/topic20629.html?highlight=drum http://www.defender2.net/forum/topic20534.html?highlight=drum If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
ah I didn't know this was a regular thing !
It is indeed see here: ![]() ![]() http://www.defender2.net/forum/topic29779....surrection ![]() Munch you could have spent the day doing something proactive for yourself instead! I went to the beach with my two daughters......Same trap I used to fall into. Not any more without a search. ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
don't worry Ive not been waiting by computer , just got out the pool with my daughter
but nice to help out with problems , if only they were real problems ![]() ![]() |
![]() ![]() ![]() It is indeed nice to help others.....especially when they need it....the thanks afterwards I find quite gratifying. Spending other people's money though.....that's even more gratifying I find. ![]() Treat every day as if it is your last....one day you will be right!! |
![]() I'm none the wiser......took thing apart and back together again.....trying to put the retaining pin / spring back on the shoe nearest the passenger side is enough to test the patience of a saint ![]() Anyhow all back together (didn�t really do anything other rebuild and a good dose of brake cleaner) and all really good (for the moment) ? I suspect one of the shoes for some unexplainable reason has a habit of sometimes getting stuck and not fully returning? Anyhow for now things seem perfect ![]() Thank you for the comments.......if they weren't helpful technically they didn't at least keep me smiling when I was getting ready to throw the town in last night with the retaining spring. ![]() |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8193 ![]() ![]() ![]() |
if it plays up again, you might find it easier to work on when its on the bench, just lift the engine/gbox and tbox out together then you will be able to see the drum and parts inside easily with plenty of space to work in. Cheers
You have the same work surface as us - are those egg yolks or satsumas in the photos?
Namaste, Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
![]() Jst I'm sure you're right but being in capable of drilling a hole in a plastic trim panel I might just give your suggestion a wade berth! ![]() |
Zd -
One of them could be an apple... Tell someone you love them today because life is short.
![]() It's gone! I hope it's not inside my brake drum ![]() Last edited by Caterham on 21st Jul 2014 10:02pm. Edited 1 time in total |
