Home > Maintenance & Modifications > hand brake tricks
Page 1 of 4 1234>
Caterham
hand brake tricks
Shocked
Going to take it apart later
Any tips on putting it back together such as putting grease anywhere, applying handbrake before tightening things up, ensuring shoes are properly located etc
Many thanks.
Post #346405 20th Jul 2014 9:06am
munch90
wash out with brake cleaner ( careful about brake dust )
grease the pivot points ( only yery small amount of proper brake heat resistant grease )
adjust so it doesn't bind !!!!!!
are you taking the shoes off the back plate ? or just drum off ?
if you taking the shoes off one trick is to take some digital pictures of it first so you know where the bit go putting it back together ( that's if you not got a workshop manual )
why are you touching it ?
Post #346415 20th Jul 2014 9:55am
K9F
If it's not giving you too much grief leave it, or get someone that doesn't have OCD or actually knows what he is doing and will not have to post prolifically on here to sort it. Please!
Whistle Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #346418 20th Jul 2014 9:58am
munch90
k9f Thumbs Up
we get some terrible / dangerous things in where people have watched a youtube video on how to do something
case of a little knowledge can be dangerous
Post #346421 20th Jul 2014 10:04am
Caterham
Not causing major problems.....
Anyhow drum now off as I come to look at posts.....
Just trying to attach photos....
This is other side which to me shows signs of rubbing
Post #346427 20th Jul 2014 10:12am
munch90
if no problems with it
quick clean out with brake cleaner
grease pivot points and shoe touching points (careful not to get grease on fiction matieral and not too much )
and back together
Post #346428 20th Jul 2014 10:15am
munch90
is that oil on the face of the drum ?
Post #346430 20th Jul 2014 10:21am
Caterham
Don't think so....?
Post #346432 20th Jul 2014 10:33am
munch90
on the inner face where the prop bolts go through ?
check the inside of the drive flange where the nut is on the transfer box to see if that is dry ?
Post #346435 20th Jul 2014 10:35am
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
Looks terminal that Shocked
Post #346482 20th Jul 2014 1:23pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
I agree with BT .... On the verge of causing endless other unrelated problems and catastrophic failures! Whistle Guns and Landrovers .... anything else is irrelevant.
Post #346485 20th Jul 2014 1:44pm
Caterham
BT - thanks for the support Very Happy
Think it looks worse in the photo than it actually is.......pretty sure the nut off T box is clean / dry. ut will have another look later.
The bottom of the right shoe has been rubbing - for some reason it doesn't seem to retract as I would have expected when the adjuster is wound in?
Will have a closer look / strip later?
Post #346486 20th Jul 2014 1:45pm
Caterham
I just thought BT was joking but if DH agrees too.......
Are you both suggesting I should torch it? .....it might just be honey on the drum not oil - I have seen quite a few bees the last few weeks - when I get back i'll link it and let you know?
After all having had a great job done on the chassis it would be a shame for it to go up in smoke. Crying or Very sad
Post #346507 20th Jul 2014 4:00pm
munch90
on a more serious note Laughing
there is a felt seal behind the washer behind the nut that can weep oil over time and the oil gets on the shoes
its a easy fix if your having the prop off I would do it any way
Post #346508 20th Jul 2014 4:04pm
Caterham
M90 - will have a look when I get back later but fairly sure there's no oil issues but will check all the same. Thumbs Up
Not sure what has caused that look of oil but it's dryish so not too concerned.
Will update later.
Post #346511 20th Jul 2014 4:13pm
Page 1 of 4 1234>
