![]() | Home > Maintenance & Modifications > Stainless steel EGR blanking kits |
Boy,
Why revert back to a standard tune at all? I miss my tune and the extra economy it afforded me! My MPG with the first two blanks gradually improved and peaked at a little over 31mpg normal driving! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
I want to compare both! |
Robofarmer Member Since: 17 Mar 2010 Location: cheshire Posts: 88 ![]() ![]() ![]() |
Karlos only just catching up on the thred after a couple of very busy wks on the farm! i see you are still having flat spot trouble. the blanks will make no difference to this problem . you will find it is down to a failed ecu patch landrover put on last time and the tune is just exaggerating the problem ! the ecu needs pilot correcting. ![]() ![]() ex 1988 defender 90 ,td ex 1970 series III |
Cheers Owen what's pilot correcting. ?? NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
JMS Member Since: 05 Mar 2010 Location: Isle of Wight Posts: 40 ![]() ![]() ![]() |
Agreed. ![]() |
Right guys should this be corrected with the tune you get or should you just try and work this
![]() IS this why Auto logic pulled their tune off the market ??????? NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
Yes it is!!! "Misfiring under load!" See the response I got page 3 on 8th June on this thread: http://www.defender2.net/forum/topic3243-45.html But you're not running on an Autologic remap? Pete from BAS should be able to advise in your situation with you running on one of his his maps! Maybe this discussion should be switched to the Autologic thread before the 'Usual Suspects' start chop flapping and gum bumping? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
er, no! |
Thanks Robofarmer,
Kit arrived yesterday afternoon!!!! ![]() Will start out on the 16mm today and see how this one works. Returning average of 26mpg in current setup. Cheers, J ![]() |
I refilled my tank today and it worked out at 20.5 mpg though I did give it a blast down the duel carrageway for a few miles yesterday (70 ish). Because this was so bad I didn't bother seeing what it would do on the standard tune but have today stepped down to the 16mm one. Hopefully I should now see an improvement like others have. Will report back.
Boy |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
Pilot correction / injector learning is not part of the read/write area of a remap which is why AL and BAS maps cant correct the LR proramming fault just by a map change. From the cars ive seen and repaired and the people who have had theirs repaird again at the dealers only the dealer tool can correct this. Ultimatly its not AL or BAS at fault because LR have failed to correctly program the ecu after a update, but as said by AL and my self without dealer tool correction to perfect a tune is very hard without lowering the overall power to try and maks a LR problem which we should not have to do. Pete Last edited by bell-auto-services on 22nd Jun 2010 11:45pm. Edited 1 time in total |
Autologic have clearly stated that the faults experienced With their maps are due to an incompatability bought in with the Q068 update! Unless you are running on a pre Q068 file you may experience 2 issues - misfiring under load and/or the reintroduction of your speed limiter! They are trying to rectify this by 'running test files' and subsequently rewriting their software to get round the 'gremlin' introduced by Q068. Hope this makes sense! As explained and sent to be on the phone and by e-mail respectively!
![]() Treat every day as if it is your last....one day you will be right!! |
Just done the first fill up the with the 16mm installed. MPG came out at 23.5 with is about normal or what I would expect it to do without it fitted considering the type of driving I was doing. I have now changed it back to standard tune and first thoughts are that it feels a lot smoother to drive and a little quieter. I will report back about mpg on the next fill up.
Boy |
Just done the next fill up and with the standard tune and the 16mm plate in it returned 23.55 and I was taking it as easy as I could. I have yet to get it on a long motorway trip but as yet I do not see a saving in MPG. I will continue for a while witht he 16mm then step down again.
