![]() | Home > Td5 > no power |
We could theorise all day, every day on what you've given us. As a starter EGR valve or oil in the injector loom. Search for both and that may give you a pointer.
If it's regular enough playing up head to your nearest independant and see what they have to say. ![]() Treat every day as if it is your last....one day you will be right!! |
Tom DCab Member Since: 13 Jun 2013 Location: West Sussex Posts: 33 ![]() ![]() ![]() |
Hi K9F,
The egr has been removed and there is no oil in the loom...so at this stage I think it must be something else... |
Try a few keywords in the search facility.
For example 'TD5 MAF' reveals 78 threads many with symptoms not unlike yours..... http://www.defender2.net/forum/topic29295.html?highlight=td5+maf If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 7th Jul 2014 4:34pm. Edited 1 time in total |
Stue5 Member Since: 06 Jul 2014 Location: Marche Posts: 111 ![]() ![]() ![]() |
Have you tried unplugging the maf sensor? I had a p38 which had a faulty maf sensor and monumental power loss which i could not track down(loss of power>more throttle=more power loss). The theory being the ecu goes to default setting when it cannot see the maf signal..... Range Rover p38 4.6 99 lpg(gone
Stue,
Good point and second post in the thread link I posted.... ![]() If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
muckybeast Member Since: 07 Mar 2014 Location: kildare Posts: 13 ![]() ![]() ![]() |
another one here for maf sensor had same syptoms replaced maf sensor and all running sweet again
tazmarkuk Member Since: 24 Jan 2012 Location: Birmingham Posts: 134 ![]() ![]() ![]() |
Have you checked the full pump is pressurising the system correctly, have seen similarly symptoms when the pump is on its way out.
