Home > Td5 > no power
Tom DCab
United Kingdom 2003 Defender 110 Td5 DCPU Oslo Blue
no power
Hi All
My TD5 defender has started to perform a new trick, and I was hoping someone could offer a diagnosis please..
Quite often after stopping and restarting engine, and especially when starting from cold, the engine runs for quite a few minutes at greatly reduced power, probably less then half power.
it doesn't always do this, but it seems to be doing it more and more regularly.
My gut feeling is that it is possibly a sensor playing up....?! But i could well be wrong.
Does anyone have any ideas what might be causing this?
thanks,
Tom
Post #343496 7th Jul 2014 3:51pm
K9F
We could theorise all day, every day on what you've given us. As a starter EGR valve or oil in the injector loom. Search for both and that may give you a pointer.
If it's regular enough playing up head to your nearest independant and see what they have to say.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #343499 7th Jul 2014 4:09pm
Tom DCab
Hi K9F,
The egr has been removed and there is no oil in the loom...so at this stage I think it must be something else...
Post #343500 7th Jul 2014 4:15pm
K9F
Try a few keywords in the search facility.
For example 'TD5 MAF' reveals 78 threads many with symptoms not unlike yours.....
http://www.defender2.net/forum/topic29295.html?highlight=td5+maf If you go through life with your head in the sand....all people will see is an ar5e!!
Post #343504 7th Jul 2014 4:33pm
Stue5
Italy 2005 Defender 110 Td5 USW Alpine White
Have you tried unplugging the maf sensor? I had a p38 which had a faulty maf sensor and monumental power loss which i could not track down(loss of power>more throttle=more power loss). The theory being the ecu goes to default setting when it cannot see the maf signal..... Range Rover p38 4.6 99 lpg(gone Sad )
Post #343505 7th Jul 2014 4:34pm
K9F
Stue,
Good point and second post in the thread link I posted.... Thumbs Up
ttuck3r wrote:
First things to do is unplug your MAF sensor and give it a whirl, sounds like something similar to what ii had next check the red plug on the ECU for oil ingress..
Post #343506 7th Jul 2014 4:36pm
muckybeast
Ireland 2005 Defender 110 Td5 XS CSW Indus Silver
another one here for maf sensor had same syptoms replaced maf sensor and all running sweet again
Post #343531 7th Jul 2014 6:20pm
tazmarkuk
England 2000 Defender 110 Td5 HT Chawton White
Have you checked the full pump is pressurising the system correctly, have seen similarly symptoms when the pump is on its way out.
Post #343533 7th Jul 2014 6:29pm
