Home > Puma (Tdci) > Cracking sound from each corner when wet |
Do you leave the vehicle stood for a little while after washing?
It could just be the brake pads sticking to the discs and the bang you hear is then releasing as you drive off. Happens more with high metallic content pads. |
7th Jul 2014 12:19pm |
milesr3 Member Since: 12 Feb 2013 Location: Suffolk Posts: 873 |
It's not from the pads sticking (rusting) to the disks; my Elise does this.
The cracking / knocking is not a one-off either, it happens every time I pull away or come to a halt; at least for a few minutes until things have dried out. My initial thought was that it was the springs moving on the platforms. |
7th Jul 2014 1:51pm |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471 |
Time to check your bushes and fixings and A frame ball joint. Steve.
7th Jul 2014 3:20pm |
Sintered pads in a Lotus can be quite amusing, especially if it's a third/fourth car and only used on high days and holidays!
Can you rule out the handbrake sticking? Definitely not TADTS. |
7th Jul 2014 4:54pm |
