Home > Puma (Tdci) > New rear dampers |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
Replacement shocks alone won't make a great difference in ride quality .... so buy whatever you are happy with.
Terrafirma are only about £35 each and will do just as good a job as the koni etc for your purposes Guns and Landrovers .... anything else is irrelevant. |
29th Jun 2014 11:41am |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 |
No, but good dampers will help with a choppy ride as they control bounce and rebound.
29th Jun 2014 11:51am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20325 |
As above, I'd also avoid Terrafirma too but each to their own.
Have you checked the condition of the bushes? |
29th Jun 2014 12:35pm |
dnorrishill Member Since: 15 Jul 2011 Location: Hampshire Posts: 615 |
Koni or Bilstein seem to be the best... have a quick search and there are a number of threads on here on this subject.
29th Jun 2014 1:53pm |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1419 |
You won't go wrong with either Darren. Bilstein was my choice for the happy bus, but I always had Koni on the cossies.
29th Jun 2014 2:10pm |
I am a big fan of the Monroe Adventure. I have had them on both Defenders and Discoveries and they performed well both on and off road.
29th Jun 2014 2:13pm |
Schw8te Member Since: 03 Jun 2012 Location: NRW Posts: 27 |
The rear springs of the Puma Defender 90 are really stiff.
A softer spring (200-230lbf/in) will give a smoother ride. Cheers Det locker bleiben |
30th Jun 2014 5:39am |
H3nry Member Since: 08 Jan 2014 Location: Heathrow Posts: 134 |
@Schw8te:
Where can you get springs with that spec? What damper would work well with the spring? |
30th Jun 2014 11:05am |
The standard rears from 90y TD5 will fit and are much softer than the TD4.
It's low cost and worth a try. Terrafirmas TF014 or Tf015 wiil do. But be warned! If you start with springs and dampers, it's a neverending story! Cheers Det locker bleiben |
30th Jun 2014 11:38am |
pob1968 Member Since: 20 Apr 2014 Location: uk Posts: 239 |
Have you tried messing with tyre pressures? If your shocks are in good shape you may be able to help the situation running a bit lower tyre pressures, I did that and it improved the drive no end. Long term I will get a set of better shocks and maybe springs but at present lowering the pressures have helped. 110 Hardtop
30th Jun 2014 12:25pm |
