Home > Puma (Tdci) > strange event |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17365 |
Check the security of the earth connections from the battery, and also check that the relays under the driver's seat are secure in their sockets. It is a fairly common problem for the relays (the main power relay and starter relay) under the seat to become loose in their sockets, usually this causes starting problems but can also cause the symptoms you describe. They should be a pretty tight fit and often aren't.
27th Jun 2014 12:40pm |
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2105 |
.... also check for a rouge earth off the starter motor cables where they may havbe worn through - this happend to me a few months ago and it was a 2 min job for my local garage to replace the wire and sort the problem. Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
27th Jun 2014 12:43pm |
dudley472 Member Since: 15 Nov 2012 Location: wolverhampton Posts: 96 |
thanks folks, I've had a look and everything seems fine, I don't know,
27th Jun 2014 7:47pm |
