strange event
this morning while driving along a smooth straight road at 40 mph I appeared to suffer a complete power failure, it seemed to only be for a second or so perhaps, I glanced down to see the tacho dropping to zero, then it came back as if nothing had happened, I have never had anything like this before, for a moment I thought I'd imagined it but noticed the trip had re set to zero, all I know to do is check the battery connections which seem fine, can anyone advise where else I can look to resolve this because it will doubtless happen again, the truck is an 09 90 cheers
27th Jun 2014 1:29pm
Check the security of the earth connections from the battery, and also check that the relays under the driver's seat are secure in their sockets. It is a fairly common problem for the relays (the main power relay and starter relay) under the seat to become loose in their sockets, usually this causes starting problems but can also cause the symptoms you describe. They should be a pretty tight fit and often aren't.
27th Jun 2014 1:40pm
wyvern
.... also check for a rouge earth off the starter motor cables where they may havbe worn through - this happend to me a few months ago and it was a 2 min job for my local garage to replace the wire and sort the problem.Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
27th Jun 2014 1:43pm
dudley472
thanks folks, I've had a look and everything seems fine, I don't know,
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
