![]() | Home > Tdi > 200 Tdi won't start unless you press the barrel in.. |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 ![]() ![]() |
New switch on the back of the barrel required. Part number PRC8230 from memory
PrivateB Member Since: 02 Dec 2013 Location: Lincolnshire Posts: 34 ![]() ![]() ![]() |
That's brilliant - Thank you very much
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
I'd recommend get a whole new ignition barrel with keys and fit this at the same time http://foundry4x4.co.uk/index.php?route=pr...duct_id=74 Much better piece of mind and you wont have to worry about warn keys or barrels.
Speek to Matt at FCX I'm sure he will be able to sort you one out ![]() |
the electric switch part on the back of the ignition lock needs replacing , not the whole lock if its not worn too much
apart from having different key replace lock complete if not sure switch is normally held in to the main lock with small screw |
+1 munch. Or if it's the original 2x screws (the bottom one you'll drop into the deepest bowels of the dashboard either on removal or refitting never to see the light of day again, don't sweat, 1 is fine
Completely agree you guys, I am a fan of doing other jobs while it is apart and accessible so was throwing it in as a suggestion.
The advice gets even better - Cheers all - very much appreciated - will be replacing it tomorrow providing local supplier has one..
And doing my very best not to lose the two screws...
It's only the one you ever loose!
All sorted now - Spot on advice - Thank you all very much
Welcome to the forum
Thanks
Thank you for the recommendation ![]() We have these in stock if you need one ![]() http://www.farrowsclassics.co.uk/X-Eng-Products.html |
