Home > Tdi > 200 Tdi won't start unless you press the barrel in.. |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 |
New switch on the back of the barrel required. Part number PRC8230 from memory
23rd Jun 2014 8:37pm |
PrivateB Member Since: 02 Dec 2013 Location: Lincolnshire Posts: 34 |
That's brilliant - Thank you very much
23rd Jun 2014 8:40pm |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 |
I'd recommend get a whole new ignition barrel with keys and fit this at the same time http://foundry4x4.co.uk/index.php?route=pr...duct_id=74 Much better piece of mind and you wont have to worry about warn keys or barrels.
Speek to Matt at FCX I'm sure he will be able to sort you one out |
23rd Jun 2014 8:41pm |
the electric switch part on the back of the ignition lock needs replacing , not the whole lock if its not worn too much
apart from having different key replace lock complete if not sure switch is normally held in to the main lock with small screw |
23rd Jun 2014 8:42pm |
+1 munch. Or if it's the original 2x screws (the bottom one you'll drop into the deepest bowels of the dashboard either on removal or refitting never to see the light of day again, don't sweat, 1 is fine )
23rd Jun 2014 8:45pm |
Completely agree you guys, I am a fan of doing other jobs while it is apart and accessible so was throwing it in as a suggestion.
23rd Jun 2014 8:53pm |
The advice gets even better - Cheers all - very much appreciated - will be replacing it tomorrow providing local supplier has one..
23rd Jun 2014 8:57pm |
And doing my very best not to lose the two screws...
23rd Jun 2014 8:59pm |
It's only the one you ever loose!
23rd Jun 2014 9:10pm |
All sorted now - Spot on advice - Thank you all very much
24th Jun 2014 8:36pm |
Welcome to the forum
25th Jun 2014 11:43am |
Thanks
25th Jun 2014 12:12pm |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678 |
Thank you for the recommendation We have these in stock if you need one http://www.farrowsclassics.co.uk/X-Eng-Products.html |
25th Jun 2014 12:17pm |
