Home > Puma (Tdci) > Bigger Fuel Tank
SkyFallSilver
Kuwait
Bigger Fuel Tank
Hello,
I love my Defender 90, however I would like a longer fuel range. Is there any replacement fuel tank that could hold more "diesel" I would love to have 1,000 KM range when I fuel up.
I don't want an Aux Fuel Tank, just something oem like with more range.
Is there such a product for me ? 2016 Defender 90 Adventure Edition
Post #340333 23rd Jun 2014 9:51pm
landy andy
Don't think there is, although Overlander/Brendan does the aux tank that fits above original tank (in wheel arch) that holds a lot of fuel and just allows the fuel to flow into the original tank, no pumps or complicated toys. You just drive around with your fuel gauge reading full for ages, whilst it fills original tank.
Andy
Post #340335 23rd Jun 2014 9:55pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Try these guys they do a great long range tank for a 110
http://www.tbruk.com 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #340337 23rd Jun 2014 9:57pm
SkyFallSilver
Kuwait
That would be great as well
Is it difficult to install ? 2016 Defender 90 Adventure Edition
Post #340338 23rd Jun 2014 9:58pm
landy andy
Post #340340 23rd Jun 2014 10:01pm
SkyFallSilver
Kuwait
What do you think of this
http://www.lrsshop.co.uk/content/long-range-90-td5tdci-fuel-tank
I don't want something that would compromise the off road clearance. 2016 Defender 90 Adventure Edition
Post #340344 23rd Jun 2014 10:04pm
landy andy
That's the one I was talking about, I believe they are good and don't compromise off road ability.
Andy
Post #340347 23rd Jun 2014 10:08pm
SkyFallSilver
Kuwait
So basically its like filling up the oem tank, no button to turn the other "tank" ?
How do you think the installation would be, difficult ? 2016 Defender 90 Adventure Edition
Post #340348 23rd Jun 2014 10:09pm
psimpson7
Australia 2014 Defender 90 Puma 2.2 XS CSW Loire Blue
It would be nice to see a picture of that tank fitted. 2001 90 HT 6.0LS/6spdAuto.
2003 90 td5 soft top.
2014 90 XS SW 2.2.
Post #340355 23rd Jun 2014 10:18pm
ngarigo
Ireland 2011 Defender 90 Puma 2.4 SW Santorini Black
ditto on that, love to see a pic of one fitted to a 90.... anyone here in oz had one of these fitted....? looks like the easiest answer to my fuel woes.... Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming...
'Wow...! What a ride!
MY11 90
Post #340369 23rd Jun 2014 11:54pm
landy andy
I think Brendan of overlander 4x4 has the wing tank fitted on his 110, and also supplies them, and has discussed fitting them at some point on here.
Andy
Post #340398 24th Jun 2014 7:19am
rtm89
United Kingdom 2010 Defender 110 Puma 2.4 USW Galway Green
http://www.safari-equip.co.uk/shop/index.p...k.html?p=1
I think a certain company I used to work for bought theirs from here.
Always had very good service.
Post #340418 24th Jun 2014 9:12am
BigRuss
What your talking about is a flow through tank that will gravity feed in to the main tank with out the need to intervene yourself. And you would just fill up as normal. Russell
2011MY 110 XS USW Black
Post #340425 24th Jun 2014 9:24am
leeds
On our black 110 we have a replacement stainless steel fuel tank with a double bottom and holds 120 litres of fuel plus a stainless wing tank double bottom that holds about 48 litres. This gives us a range of over 850 miles, have not pushed it to the limit to find out exact range, but when orange light goes on have about 30-40 litres left in tank.
We can supply a 120 litre replacement tank for a 110 in mild steel from about £550 plus carriage. Stainless steel and double skinned bottoms are extra.
48 litre wing tanks for a 110 start from about £350 in mild steel plus carriage.
Large main tank does not interfere with departure angle.
Wing tank does not effect articulation. We run 33" tyres and a 2" lift. If tyres are full of mud and high articulation then the mud on tyre might catch on tank.
Wing tanks for TD5/TDCi holds about 30 litres and are plastic. If you have a roll cage fitted it may cause some issues with fitting a wing tank. We supplied one to DaveW and PamW for their 90 for their Australian trip. I think there is some information on their blog about fitting one to a 90
It is easier to fit wing tanks with wheel off and preferably on a 4 post lift. Probably the fiddlest/awkward bit is fitting the connecting fuel pipe.
Depending on what tank you have fitted you may have to drill a hole in main fuel tank for balance pipe. Best done with an empty tank!
Brendan
Post #340459 24th Jun 2014 12:40pm
leeds
Re: Bigger Fuel Tank
SkyFallSilver wrote:
Hello,
Looking at official figures the 90 has a 60 litre fuel tank and combined fuel consumption of 10 litres/100km.
However fuel consumption is very much dependent on on driving style, vehicle condition and terrain being driven over. Low box and soft sand could easily see fuel consumption rise to say 12.5 litres/100 km or even higher.
For a range of 1,000 km that would mean a minimum of 100 litres fuel required.
The plastic wing tank which is a flow through tank holds about 30 litres and is suitable for a TDCi.
A LHS sill tank exists for a TD5 and holds about 40 litres whereas the RHS sill tank holds 50 litres.
Would these fit a TDci? That I would have to check out. Also will they impinge on ground clearance? They are a pump system rather then a flow through system.
Brendan
Post #340622 24th Jun 2014 9:50pm
