Home > Technical > TOWING TWO TRAILERS - LEGALITIES?
smb
Not sure if it should come under the Technical heading, but does anyone know(hopefully Blackwolf will be reading this Exclamation Bow down ) whether you can legally tow two trailers behind a Defender on UK roads?
I am looking at using my 110 to tow my Widetrack which has a Nato Hitch fitted instead of the standard jaw hitch, thereby enabling me to tow my Narrowtrack behind it. Weight wise, the total train weight inclusive of load will be under what is permissible. All the lights will work in unison as I have made and adapted the electrical cables. Whether it has any bearing on the legalities, it will not be travelling more than 15 miles between the two premises.
Thanks in advance for your assistance. Thumbs Up
Steve
Post #339439 20th Jun 2014 12:35pm
rustyboxx
United Kingdom 2015 Defender 90 Puma 2.2 CSW Montalcino Red
I think you require a showman's licence to do that. I asked the DVLA some years ago when I wanted to tow a woodchipper behind an Ifor Williams trailer behind my old 90. It was a no-go on an ordinary licence and HGV licence that I had at the time. 2015 90 XS CSW TDCi - Beautiful
2007 110 XS DCPU - An itch that needed scratching
2005 90 Td5 XS CSW - Utterly brilliant
2001 Discovery 2 ES Auto - A phase I went through
1996 90 Tdi CSW - Uber reliable
1989 90 2.5 Petrol Hardtop - My first proper Landy
1985 Range Rover Vogue V8 -Troublesome
Post #339446 20th Jun 2014 12:44pm
Surrey Rover
Agricultural and showmen only. Nick
2.2 110 Tipper
Post #339447 20th Jun 2014 12:45pm
Mountain_man
Wales
Have done it with 2 14 tonne silage trailers, empty, on the way to a job. Thank goodness I didn't have to back up in the lanes!
Post #339468 20th Jun 2014 2:53pm
JWL
I did it once with 3 small artic bale trailers, it was all right but had to pull over when a lorry was trying to overtake, there was literally no road left! Then when I went to turn into the field they were too much for the gateway, had to drop them off and take them in individually Embarassed
Saying that I was loading the back 2 without unhitching and without tying myself in knots. We reckoned the whole lot measured around 100' Mr. Green
Post #339472 20th Jun 2014 3:09pm
As stated above, no, sorry, it'd be fun.
Unless you're ag or showman registered, or operating under Crown exemption, it's illegal.
Post #339493 20th Jun 2014 5:28pm
jimbob7
Denby haulage tried it....once.
 Pov.spec,ftw. 2006, 110,TD5.
Post #339499 20th Jun 2014 5:43pm
smb
Censored ! Oh we'll, suppose I will have to do two journeys.
Thanks for replies. What is meant by Agricultural registered? Is it a special qualification on your driving licence like showman or something else? I have two holding numbers for the land I will be going back and too from and it will not be for Hire or Reward. I just want to transport wastage from trimming of trees and hedges to my farm to burn.
Post #339510 20th Jun 2014 6:16pm
rustyboxx
Well at least you won't need a waste carrier's licence if you produce it yourself Smile 2015 90 XS CSW TDCi - Beautiful
Post #339513 20th Jun 2014 6:19pm
rustyboxx
Oops, double post 2015 90 XS CSW TDCi - Beautiful
Post #339514 20th Jun 2014 6:20pm
JWL
Agricultural purposes........agricultural products, agricultural registered/taxed towing vehicle plus limited speed.
Post #339519 20th Jun 2014 6:35pm
barbel jim
Got pulled a few years back, Tractor, 2 silage trailers and the van on A frame.............. Back then it was max 2 pivot points and 67 feet max train length Embarassed
Post #339522 20th Jun 2014 6:43pm
Defender SVX
United Kingdom 2008 Defender 90 Puma 2.4 SVX Soft Top Santorini Black
There's no such thing as a "showmans licence" or even a catorgry on your licence! It becomes similar to agricultural if the stipulations are met.
I'm no expert and can't quote the full stipulations but I believe in agricultural the motive vehicle has to be agricultural registered as such and subject to speeds etc.
Showmans vehicles are also subject to similar rules ie taxed as showmans vehicle, the driver only needs to be licenced for the type of vehicle (class1 or C+E) as it is for hire or reward, also subject to speed limits.
I have had experience of heavy haulage though where depending on the size they become categorised STGO either 1,2,3. Under cat 3 (the largest) your prime mover (front truck) becomes a locomotive, ballasted and with many pivots within a "train" of load and potentially several vehicles. All movements need to be notified to the authority's and escorted with ridiculous speed limits that are never enforced.
Basically for you it's going to be two journeys to keep within the law Whistle
Make me think of this Rolling with laughter
 Formerly mao99999
16 Focus RS Nitrous Blue.
11 FFRR TDV8 Vouge SE Black Black.
08 DEFENDER SVX SOFT TOP (SUPERB)
08 DEFENDER 110 DCPU Stornoway grey (Overland Exploration Unit)
05 Fiesta ST 150 Van
04 Jaguar XKR 4.2 Supercharged V8
02 DEFENDER 90 TD5 (next years soft top project)
95 DEFENDER 110 CSW 300 TDi Phoenix black
95 DEFENDER 90 HT Monti Carlo blue COUNTY 300 TDi
67 109" SERIES 2a TUNED 200 TDI
64 DAVID BROWN 990 rat look
55 86" SERIES 1
Post #339536 20th Jun 2014 7:22pm
Defender SVX
He only got picked up by overall length! Not the pivot points Whistle hat off to the guy Bow down A pioneer within the industry.
My dad used to run this as the second pivot (a 5th wheel) couldn't be parted unless by mechanical means ie a welded bolt in the locking handle:-
P.s maybe that is a way for SMB to carry out the movement Question pin the first NATO hitch and place a spot weld on the pin. Formerly mao99999
55 86" SERIES 1
Post #339544 20th Jun 2014 7:40pm
smb
Mao99999, thanks for posting the photos. That was exactly what I was thinking. Good to know it can/has been done.
Post #339551 20th Jun 2014 8:13pm
